![]() | Home > Maintenance & Modifications > windscreen wipers |
TrevG Member Since: 14 Aug 2012 Location: Kent Posts: 48 ![]() ![]() ![]() |
I got these no issues so far |
defender_uk Member Since: 08 Aug 2006 Location: North Yorkshire, Pickering Posts: 169 ![]() ![]() ![]() |
same boat as u Ilard.... |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9097 ![]() ![]() ![]() |
I have found the LR supplied wipers to be as good as any others and better than some. 2012 SDV6 - it's missing a couple of cylinders
Try giving the windscreen a really thorough clean with Autoglym fast glass and then apply Rain X rain repellant. If the wipers still squeak or judder try twisting the flat metal part of the wiper arms a little to change the angle of attack by a small amount. This might require a bit of trial and error until it is just right. 2008 MY Java Black TDV8 HSE
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Good advice, Paddi, my screen probably needs some TLC to help get the most out of the wipers. I think the guy who cleans my car is more of a splish splash splosh sort of a fella. But my ineptitude at tweaking / fettling / DYI is infamous in my household so I better leave that to someone else. |
zee Heyner Hybrid wiper blades have worked out well and certainly have a nice swipe about them. Only issue is that they look abit ugly from the driver's seat because the clip structure is exposed - i.e. no spolier cover. I wonder if I was supposed to remove a part of the old wiper blades.... |
Java SC Member Since: 23 Mar 2013 Location: North Wales Posts: 21 ![]() ![]() |
Just ordered the above for the front and the below for the rear... http://www.ebay.co.uk/itm/Complete-rear-wi...7431195%26 I will let you know how I get on..... Java RRS Supercharged + Jaguar STR Supercharged, = Oil Refinery.... ![]() |
