Home > Maintenance & Modifications > Singing brakes |
Hi All
Mon Mar 11 2013 3:10pm |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
Or you've got some grit or small stone stuck in there.
Mon Mar 11 2013 3:58pm |
cheers Enjin.
Mon Mar 11 2013 4:01pm |
If that doesn't work then find a friendly garage with a pressure air hose and get them
Mon Mar 11 2013 4:16pm |
norlan Member Since: 21 Jun 2011 Location: Moray Firth Posts: 45 |
Had this a while ago and it turned out to be a sticking brake piston. |
Mon Mar 11 2013 7:07pm |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
Very badly worn pads on worn discs will do that too, but shouldn't be speed dependent.
Mon Mar 11 2013 9:15pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4395 |
If the noise is coming from the rear, it could be the beginning of seized EPB shoes |
Mon Mar 11 2013 11:21pm |
