Home > Maintenance & Modifications > Singing brakes
Singing brakes
Hi All
My brakes have suddenly started to squeek when warm.... at around the 10-20mph when in traffic... bloody annoying!
Is this the 1st indication of "end of wear" fast approaching? RRS gone
Post #376340 Mon Mar 11 2013 3:10pm
Endjin
Scotland
Or you've got some grit or small stone stuck in there.
Happened to me a few times. Usually cleard by hard
breaking (like emergency stop) to throw it out. Obviously
when nothing is behind you! Embarassed Embarassed Whistle 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby)
GONE - RRS - 3.0 TDV6 HSE - Santorini (2010)
GONE - RRS - 2.7 TDV6 HSE - Java Black (2007)
GONE - Porsche Boxster S - 3.2 - Black
Post #376349 Mon Mar 11 2013 3:58pm
cheers Enjin.
I'll try it out Whistle RRS gone
Post #376350 Mon Mar 11 2013 4:01pm
Endjin
Scotland
If that doesn't work then find a friendly garage with a pressure air hose and get them
to give the brakes a blast. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Post #376356 Mon Mar 11 2013 4:16pm
norlan
Scotland 2008 Range Rover Sport TDV8 HST Stornoway Grey
Had this a while ago and it turned out to be a sticking brake piston.
Post #376381 Mon Mar 11 2013 7:07pm
If you're clearing a stone from brakes, it sometimes work better to brake in reverse as the stone is often near the leading edge of the pad for obvious reasons. 2012 SDV6 - it's missing a couple of cylinders
Post #376386 Mon Mar 11 2013 7:48pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Very badly worn pads on worn discs will do that too, but shouldn't be speed dependent.
"Roads ? Where we're going there are no roads." Back to the future.
Post #376400 Mon Mar 11 2013 9:15pm
Disco_Mikey
If the noise is coming from the rear, it could be the beginning of seized EPB shoes
Post #376416 Mon Mar 11 2013 11:21pm
