![]() | Home > Technical > sat nav |
smurf Member Since: 16 Aug 2010 Location: cheshire Posts: 81 ![]() ![]() |
can anyone help,my sat nav puts me somewhere down south when clearly i am in the midlands.
jimbg Member Since: 29 Jan 2013 Location: By the River Dart Posts: 1856 ![]() ![]() |
Has it just started doing this? Do you have option to look at the satellite signal strengths in your menus's Has the car been moved 10's of miles with the system shutdown? |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 ![]() ![]() |
You can calibrate the Sat Nav in the settings menu. try that first.
I tried to calibrate it via the menu but it didn't work,and yes it has been on the back of a breakdown truck lol |
OK, that is why it is confused!!
you can try disconnevcting the + cable off the battery and touching the + CABLE to the body. Just make SURE that the battery is definately disconnected and you dont have an Aux battery installed as well.
