![]() | Home > General > MY08 vs MY12 Xenons |
Did you have the old car from new?
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 ![]() ![]() ![]() |
I don't mind swapping my headlights . |
AntRover Member Since: 28 Feb 2013 Location: Warwickshire Posts: 50 ![]() ![]() |
Yes, had the car from new. I have noticed that the older headlamp assembly was slightly bigger. I just wondered if the bulbs weren't as bright or the lense made for a reduction in light pattern. 2018 RR Velar R-Dynamic, Silver/Ebony, Privacy Glass, lots of toys
Headlights on the older cars are brilliant |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
ISTR reading that the new lights have a flatter top to the beam so they don't need to have the beam adjuster for driving on the wrong side of the road. I wonder if you're noticing the lack of 'kick up' in the beam on the nearside - this will make it seem as if they aren't as good because you don't have that reflected light from near the vehicle on the nearside.
It's a good possibility to be either or both those suggestions. I'll run some checks on the adjustment screws.
I'll bear it in mind ![]() 2012 RRS HSE Lux SDV6, Orkney/Ivory, Privacy Glass, Side Steps and Tow Pack (Gone) 2008 RRS HSE TDV6, Stornaway/Ebony, Privacy Glass, Tow Pack (Gone) 1985 LR Series 3 SWB, Canvas Top, Firestone SATs (Gone) |
