Home > General > Advice needed please ! Check Engine Light on ! |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
You need to read the fault codes to know. Could be eleventy seven things. My guess is EGR valve as it sticks when hot but don't take that as gospel. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Wed Feb 27 2013 7:03pm |
JimKim Member Since: 09 Jun 2012 Location: Didcot Posts: 90 |
Thanks mate I'll leave it over nite and see what it dose when cold S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Wed Feb 27 2013 7:39pm |
StuRRS Member Since: 18 Jan 2013 Location: Gloucestershire Posts: 92 |
Had exactly the same 2 weeks ago, diagnosed by stealer as EGR valve faulty, dropped off this evening for replacement tomorrow, £370 to you sir
Wed Feb 27 2013 7:42pm |
hope it's covered under warranty S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Wed Feb 27 2013 8:01pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8985 |
My understanding is that anything that affects emissions will throw up the "engine light". 2012 SDV6 - it's missing a couple of cylinders
Thu Feb 28 2013 9:14am |
There are two systems, the management light and the DIS which shows faults on the LCD display. There is not consistency to how these work. You can get a DIS fault which does or doesn't record in fault log. Same with light. When mine self distructed there was no light but a DIS message. When log was checked, one error for boost deviation was logged but was historical not current. So the system is not infallible. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Thu Feb 28 2013 9:32am |
Yep EGR S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Thu Feb 28 2013 5:29pm |
PM'd you Stu
Fri Mar 01 2013 8:52am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
If your car is out of warranty then take it to an independednt to get this fixed. No point paying main dealer prices. I'm sure someone on here in your area could recommend a good one for you. 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black 2013 Evoque 5 Door Pure Tech SD4 - Orkney Grey with Panoramic Roof (Mrs E's new baby) GONE - RRS - 3.0 TDV6 HSE - Santorini (2010) GONE - RRS - 2.7 TDV6 HSE - Java Black (2007) GONE - Porsche Boxster S - 3.2 - Black |
Fri Mar 01 2013 8:57am |
She's off to James French don't fancy mine being test drove at warp speed by Hartwells S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Fri Mar 01 2013 8:07pm |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
What year is your RRS?
Fri Mar 01 2013 8:31pm |
It's an 07 57 plate S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Fri Mar 01 2013 8:36pm |
Not possible then, same year as mine. Did you notice any symptoms before the engine light appeared? Ie. Performance loss, poor MPG etc. 2014 L405 SDV8 RR Autobiography 2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone 2007 RRS TDV6 HSE - Zermatt Silver - Gone |
Fri Mar 01 2013 8:42pm |
Nope nothing just wondering weather letting it get low on fuel triggered it although the light came on a mile from the garage so wasn't on fumes S, grey, all black int, s,steps, window tints, fridge, ff tv x 3. |
Fri Mar 01 2013 8:50pm |
