Home > Technical > Water in fuel
Defty201
2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Water in fuel
My RRS 57reg says water in fuel, had to the garage and had the fuel filter changed and the water sensor changed as well but still says water in fuel.
Does anyone have any ideas?
Thanks Liam
Post #373917 Mon Feb 18 2013 9:16pm
Paddi
Check the obvious first - did the garage remember to reconnect the water sensor? Not sure if this would give you a false reading but it is easy enough to check with a visual inspection.
Is it possible you took on some contaminated fuel? Did you fill up somewhere other than your usual place?
Has been known for fuel stations to have water in their tanks. To be on the safe side perhaps you should have the fuel in your tank tested or drained. Might be cheaper than having the engine trashed if there really is water in there? 2008 MY Java Black TDV8 HSE
Post #374108 Wed Feb 20 2013 12:08pm
Disco_Mikey
The water in fuel sensor is actually part of the filter housing.
If it has already had a sensor and filter replaced, it will need a new housing
Post #374164 Wed Feb 20 2013 8:59pm
Defty201
Thanks for all the answers.
It's typical that it's been on for weeks so I rang land rover yesterday and they said it sounds like a snapped wire, so had it booked in for 11 march.
Then gets in car this morning and its gone off!!!
Thanks Liam
Post #374342 Fri Feb 22 2013 12:53pm
Bradders
Had this on and off a few months ago - the message eventually went off and has been off since. FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #374343 Fri Feb 22 2013 1:38pm
Mine came on during the floods.... sensor is prone to shorting/earthing in it's low position.
Leve it a while... mine went off (like Bradders) and hasn't come back on RRS gone
Post #374371 Fri Feb 22 2013 3:33pm
