![]() | Home > Maintenance & Modifications > Rear ARB leaking - O-Ring replacement? |
RRSTDV8DK Member Since: 26 Mar 2007 Location: cph Posts: 67 ![]() ![]() ![]() |
My rear ARB is leaking and i have been told it needs to be replaced. I seam to remember reading somewhere that it sometimes can be fixed by replacing the O-Ring. Is that correct and does anybody know if this is a kit and the partnumber?
Were you thinking of this thread? http://www.rrsport.co.uk/forum/topic19778.html?highlight=o+ring 2008 MY Java Black TDV8 HSE
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9049 ![]() ![]() ![]() |
Have a trawl through Bobby's gallery: http://rrsport.co.uk/gallery/index.php?cat=10024 2012 SDV6 - it's missing a couple of cylinders
nope - not there RRS TDV8 HSE in Stornoway Grey/Alpaca/Rhodium/Multimedia/Privacy Glass |
In order to correctly diagnose the leak path on a stabilizer bar, clean the suspected area thoroughly and confirm if
... these are serviceable parts and should be replaced. If the leak is found to be from the hydraulic seal, this is not a serviceable part and a new stabilizer bar will be required. ![]() 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Well done Bobby! |
No problems. Would have responded to this sooner, only thing is that I was in the UK at that time! Was raining, in addition to being cold!! Took the Eurostar to Paris on 14th... and back home now. Cheers!! ![]() PS - Wonder if this helped RRSTDV8DK ? Malaysia Boleh! 4.2SC Chawton White, Stormers Tasmod's Sills, Wind Deflectors, LR Sills Clear Side Repeaters, Towbar Larini Sports Exhaust, K&N Air Filter ______________________________ WINNER - 2008 'Tech-Head Of The Year' Award WINNER - 2009 Outstanding Contribution WINNER - 2009 'Tech-Head Of The Year' Award |
Tommyschuck Member Since: 19 Jan 2012 Location: Austria Posts: 15 ![]() ![]() |
Does anybody know the torque of this two little bolts on the picture above? |
Hi Bobby
TheDB Member Since: 07 Apr 2009 Location: Southerner Posts: 96 ![]() ![]() ![]() |
Hi Bobby, Same for the front ARC stabiliser bar? |
Yes. |
