Home > Tips & Tricks > HELP: Alternative expedition roof rack fitting
Silverc
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
Help please!!!
Does anyone have any experience in fitting the Expidition roof rack to the RRS using the plastic spacer fittings (supplied with VUB504230)? ie. NOT using the roof gutter accessory (supplied as part of VUB502130).
I would be interested on views as to fitting the expedition roof rack with this method relative to the roof rail methoud, relating to:
*wind noise / fuel consumption
* stability / alignment
* load capacity
Hopefully, apart from a minor aesthetic difference, the method of using the (6) plastic spacers works fine.
Thanks for the help!
Post #316360 Thu Oct 06 2011 12:35pm
Had my rack fitted both ways and as you say apart from the appearance there isn't much difference in noice, stability etc. Removing the rack isn't so easy and I would suggest the rails as your fixing point. 2005 Zambezi TDV6 - Gone but not forgotten
Post #316363 Thu Oct 06 2011 12:43pm
scenery
United Kingdom 2008 Range Rover Sport TDV6 SE Orkney Grey
How did you fit it in the end?
I have just got a G4 rack.
Do I need to buy another kit other than the fitting kit with the rack?
The instructions are very confusing and involve a 19mm hole cutter
any advice appreciated Range Rover Sport tdv6 2.7
2008
Post #373687 Sat Feb 16 2013 1:42pm
Silverc
I used the spacers (a set of 6 plastic mounts that fit onto the existing gutters. However, either way requires you to drill the holes in the gutters to a larger size.
Bear n mind that I think the standard mounts that come with the G4 rack are metal and are meant to be fitted onto the roof rails (an additional purchase from LR). If they are plastic, then they can go directly onto the gutters after you have widened the holes. Good luck
Post #373783 Sun Feb 17 2013 8:43pm
scenery
Thanks
I have the plastic mounts and I presume when you say drill the gutter you mean the removable plastic gutter insert
Steve Range Rover Sport tdv6 2.7
2008
Post #373794 Sun Feb 17 2013 9:31pm
Silverc
Its actually an aluminum gutter insert.. its the 2 long black strips that sit on top of the roof with 6 plastic round covers holding it in place.
Post #373820 Mon Feb 18 2013 6:29am
scenery
Thanks for that I will do that this week
2008
Post #373826 Mon Feb 18 2013 9:27am
