![]() | Home > Faults & Fixes > Alarm keeps going off, and the horn sounds once when trying |
Sit in the car, ignition on, should tell you Bonnett Open on the dash display.....
s1mon Member Since: 14 Feb 2013 Location: South East Posts: 5 ![]() ![]() ![]() |
Thanls for the info mate, a cheap fix if its only a tenner! Current rides - RANGE ROVER SPORT 4.4 V8 HSE BMW 535D M SPORT LANCIA INTEGRALE EVO 2 DEALER COLLECTION |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4424 ![]() ![]() ![]() |
Even cheaper, get s small piece of wire and bridge out the terminals on the bonnet switch connector |
Exactly what I ended up doing, and it's been fine since! - New bonnet switch now on order, ![]() RANGE ROVER SPORT 4.4 V8 HSE BMW 535D M SPORT LANCIA INTEGRALE EVO 2 DEALER COLLECTION |
K80tcg Member Since: 29 Mar 2013 Location: Verwood Posts: 25 ![]() ![]() ![]() |
Hi I have the same problem, alarm goes off says bonnet open.
A quick search would have brought you here...
maci234 Member Since: 12 Oct 2014 Location: scotland Posts: 175 ![]() ![]() ![]() |
panel says drivers door open sometimes when its closed where is the sensor for door |
|Door lock actuator then would be a good place for you to start they are know to give issues |
it doesn,t do it very often so far but it has sent alarm of and it states drivers door open on dash are these actuators sealed units |
