Home > Faults & Fixes > Alarm keeps going off, and the horn sounds once when trying
s1mon
United Kingdom 2006 Range Rover Sport 4.4 V8 HSE Santorini Black
Evening all,
Only had the Sport for a week, and we seem to have a little problem with the alarm going off as and when it feels like it, then when you open and try to re-lock the car on the fob the horn sounds once.
From what I have read on here this means that the car is being told that something is open.
I am assuming as from what I can gather there is no way of testing the door sensors as they are sealed units? But the bonnet sensor can be tested. What I have done is disconnect the wire leading to the bonnet catch on the drivers side and inserted a bit of foil in between the wire plugs, is this the correct method?
If so, I will see if it does the job and then replace the sensor / latch. Failing that if the alarm continues to go off I guess it will be a trip to the dealers! Current rides -
RANGE ROVER SPORT 4.4 V8 HSE
BMW 535D M SPORT
LANCIA INTEGRALE EVO 2 DEALER COLLECTION
Post #373702 Sat Feb 16 2013 5:57pm
Bodsy
Site Sponsor
Sit in the car, ignition on, should tell you Bonnett Open on the dash display.....
Replacement is about £10 or so, easy to replace yourself. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #373705 Sat Feb 16 2013 6:38pm
s1mon
Thanls for the info mate, a cheap fix if its only a tenner! Current rides -
BMW 535D M SPORT
Post #373709 Sat Feb 16 2013 6:50pm
Disco_Mikey
Even cheaper, get s small piece of wire and bridge out the terminals on the bonnet switch connector Thumbs Up
Post #373731 Sun Feb 17 2013 8:36am
s1mon
Exactly what I ended up doing, and it's been fine since! - New bonnet switch now on order, Thumbs Up Current rides -
BMW 535D M SPORT
Post #373779 Sun Feb 17 2013 7:28pm
K80tcg
England 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi I have the same problem, alarm goes off says bonnet open.
Where is the sensor on the car for the bonnet? Is it just an unscrew unplug and replace item?
Does anyone have a picture of what I am looking for, is a by pass wire the best option or a replacement part off flea bay? Tdv8 range rover sport
911 turbo s
BMW GS1200 A
Post #381775 Mon Apr 29 2013 9:22pm
Bobby
A quick search would have brought you here...
http://www.rrsport.co.uk/forum/post285080.html#285080
Cool Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #381785 Mon Apr 29 2013 11:04pm
maci234
panel says drivers door open sometimes when its closed where is the sensor for door
Post #564852 Sun Sep 09 2018 7:22pm
geoffsnook
|Door lock actuator then would be a good place for you to start they are know to give issues Thumbs Up
Post #564854 Sun Sep 09 2018 7:25pm
maci234
it doesn,t do it very often so far but it has sent alarm of and it states drivers door open on dash are these actuators sealed units
Post #564860 Sun Sep 09 2018 7:33pm
