Home > Technical > Just A Question
madmackie
United Kingdom 2005 Range Rover Sport TDV6 HSE Bonatti Grey
Just A Question
I dont think anything is wrong but ive just noticed (it hasnt been started for two days) when i strted my car the sat nav screen seemed to flicker and go brighter when i revved uo the car once i had strted to move all was fine i did notice though the heater plug light seemed to take a aboout 10 seconds to go out when i started it it then cut out had to do it again wait for glow plug light to go out then fine is this normal as it has been really cold here the last two days thanks pete also how difficult is it to change the plugs car has done 85k cheers "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373126 Mon Feb 11 2013 7:03pm
madmackie
Anyone any ideas please "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373202 Tue Feb 12 2013 2:36pm
might be signs of a tired battery.
If you're lucky, the warmer spring weather (laughs) might prolong it's life till Autum Mr. Green RRS gone
Post #373208 Tue Feb 12 2013 3:37pm
madmackie
It is a new battery cheers "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373210 Tue Feb 12 2013 3:41pm
Battery terminals all tightened Question ON THE WAY: BMW F21 M140i
Post #373215 Tue Feb 12 2013 3:51pm
madmackie
Yes i checked them the other day and they appeared loose so i tightend them will check again though Thumbs Up
approx 10 secs for glow light to go out is that normal and how many times should i do the cycle in cold weather cheers
Just checked battery all terminals tight "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373221 Tue Feb 12 2013 4:15pm
Seems quite a long time to me, I know mine is a new car, but this morning in -1 it took 2 seconds. Neutral ON THE WAY: BMW F21 M140i
Post #373223 Tue Feb 12 2013 4:19pm
madmackie
does anyone know ho whard it is the change them they are approx £45 for six "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373224 Tue Feb 12 2013 4:20pm
Quote from Bell Auto's
"It's the injectors out, injector rails off, rocker covers off etc etc a BIG job. "
Doesn't look like a straightforward job Sad ON THE WAY: BMW F21 M140i
Post #373225 Tue Feb 12 2013 4:32pm
madmackie
cheers has anyone heard of this recall TSB is LTB00047v2 "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373226 Tue Feb 12 2013 4:52pm
Bobby wrote:
Anyway, have just looked my notes - this TSB is LTB00047v2 and it covers
2.7L (TDV6) Diesel Engines, VIN-range: 5A900505-6A966000.
All I can find on here for you Thumbs Up ON THE WAY: BMW F21 M140i
Post #373228 Tue Feb 12 2013 4:57pm
madmackie
Thanks beancounter how do i check the vin number which part of it i tink it starts with saall or something as if mine falls into this bracket it might not have been done so i assume i can check it out Thumbs Up "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373229 Tue Feb 12 2013 5:04pm
madmackie
just checked mine does fall into the said window of chasis nukbers what do i do now and how do i find out thanks pete "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373230 Tue Feb 12 2013 5:06pm
I suppose you can call a dealer and find out if the TSB was ever applied to your vehicle - I assume they keep such things on a central database.
If it's not been done, then I guess they should call you in to carry it out. Thumbs Up ON THE WAY: BMW F21 M140i
Post #373231 Tue Feb 12 2013 5:17pm
madmackie
cheers Thumbs Up Thumbs Up "Remember its easier to say sorry than it is to get permission " especially off the Mrs !!
Post #373232 Tue Feb 12 2013 5:27pm
