Home > In Car Electronics > Two reversing cameras for RRS SC + Large box trailer
lovejoy
United Kingdom 2005 Range Rover Sport Supercharged Tonga Green
I want to fit a reverse camera to my '05 RRSport and another one to my large box trailer. I've read all about GVIF units, but they all seem to only have one camera input.
Ideally the car cam should be on when reversing up to the trailer and then the trailer cam should be on when I'm hitched up.
Some sort of simple dashboard switch? Has anyone done this?
Thanks Confused
Post #373108 Mon Feb 11 2013 5:37pm
PEACHY
Bodsy - fitted mine - I have the reversing camera & a Blackvue fitted to the GVIF unit. The reversing camera defaults in reverse & the Blackvue can be watched via the sat nav screen at the press of a button - so there may be a solution. I don't know how you would overcome the connection when attached to the trl. Sad send him a pm - he likes a challenge. Thumbs Up 16MY Estoril Blue SVR.............
Post #373116 Mon Feb 11 2013 6:26pm
lovejoy
Thnx PEACHY. Can't PM yet as I'm a newbie. Hopefully Bodsy will see the post. 2005 RR Sport SC with BRG Twin Vaporiser LPG conversion. My first RR and I LOVE it! 10,000 miles so far on LPG...some in Belgium @ 55p per litre...the best car in the world?
Post #373118 Mon Feb 11 2013 6:35pm
PEACHY
I've let him know Thumbs Up 16MY Estoril Blue SVR.............
Post #373119 Mon Feb 11 2013 6:37pm
lovejoy
Thanks Martin, much appreciated. Thumbs Up 2005 RR Sport SC with BRG Twin Vaporiser LPG conversion. My first RR and I LOVE it! 10,000 miles so far on LPG...some in Belgium @ 55p per litre...the best car in the world?
Post #373120 Mon Feb 11 2013 6:40pm
PEACHY
pm sent - lovejoy check your in box Shocked Thumbs Up 16MY Estoril Blue SVR.............
Post #373122 Mon Feb 11 2013 6:48pm
Bodsy
Site Sponsor
Lovejoy,
Not a problem to do what you want to do. The GVIF unit has a reverse Cam input as well as three additional A/V inputs.
Only question, is how you want the camera from the trailer to be connected to the car. Either a Wireless unit or a curly long wire from the car.
GVIF will automatically use the reverse cam when in reverse. All the other time, yoiu can put on whichever one you want. Either by pressing the descrete button or using the remote control to change A/V inputs.
You can even have a splitter on the reverse cam input so it also displays on one of the A/V's as well.
I'll drop you a PM with my contact details. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #373158 Mon Feb 11 2013 11:05pm
Daiboy
Hi Bodsy what would you charge to fit a gvif and number plate camera to my beloved rrs, thought I could take on the challenge, but have now bottled it.. I live in swansea and am led to believe you travel around Britain doing this sort of stuff.
Hope you can help
Dai New owner very pleased with it......
Post #374117 Wed Feb 20 2013 2:03pm
flydive
Bit of work, but you could make the following set up.
A splitter that feeds both cameras to the GVIF reverse cam imput.
A toggle switch that powers either camera, car camera or caravan camera.
To make it neater you could use the output that tells the car that the caravan is connected to control a relay to switch camera automatically. A bit more wiring needed. '08 RRS TDV8
Post #374122 Wed Feb 20 2013 3:31pm
Daiboy
Sorry chaps I was trying to pm bodsy doh New owner very pleased with it......
Post #374124 Wed Feb 20 2013 3:43pm
