Home > General > Why can't Land Rover get it right? |
I think you just have a bad one. Problem is the most simple of things with modern cars can be difficult to trace due to the complexity of systems.
Sun Feb 10 2013 10:59pm |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 |
Absolutely ridiculous. Sorry to hear you are having problems. Change the dealer probably? Vadim A. |
Sun Feb 10 2013 11:12pm |
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 529 |
Sun Feb 10 2013 11:42pm |
Foxy had this problem with her 11 plate sport too, she also had a problem with the battery terminals not tight enough which caused all the lights to light up on the dash and reduced performance to the point where it stopped. Take it straight back to the stealer. No better still, next time it happens, call out L/R assist that way if it has to go into the dealer for repair you will get a like for like courtesy car, if you just take it back to the stealer you will end up with whatever they have kicking around which might no be suitable for your needs. But i think this sounds like a friday afternoon car mse, not friday morning. |
Mon Feb 11 2013 7:41am |
ARHRRS Member Since: 14 Jan 2010 Location: Birmingham Posts: 36 |
Thank you for your replies.
Mon Feb 11 2013 8:49am |
It will of logged a fault code in the ecu so L/R will be able to identify the problem through this. |
Mon Feb 11 2013 8:54am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8978 |
Did you buy it new? Reject the vehicle. 2012 SDV6 - it's missing a couple of cylinders
Mon Feb 11 2013 9:48am |
They dont work many Friday afternoons though although i think they are at the moment Mike 2014 Facelift Discovery |
Mon Feb 11 2013 9:55am |
The track shuts down on Friday afternoon depending on production, you are right there shouldnt be Friday cars, but there are. As for Birmingham dealers - Guy Salmon Cov/Stratford are your nearest good pair. Mike 2014 Facelift Discovery |
Mon Feb 11 2013 9:57am |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
As mentioned above, get L/R Assistance to recover the car next time it happens.
Mon Feb 11 2013 10:07am |
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 |
I think that as cars become more complex, resulting in many reasons why things don't work, dealership will struggle more and more to find faults.
Mon Feb 11 2013 10:54am |
Totally agree - As earlier post's including mine have mentioned, the tiniest of faults eg a trapped wire or rubbing wire, can cause serious issues and given the miles of cables etc - its so easy for everyone to experience a different fault cause by different systems interacting in the wrong way.
Mon Feb 11 2013 10:59am |
These machines have computer code akin to products from Microsoft.
Mon Feb 11 2013 12:48pm |
^^^^ I wouldn't be trying that on a new motor |
Mon Feb 11 2013 1:40pm |
