Home > Technical > Seems I must choose between Blackvue and Pre-Heater!
Jonny Fresh
My pre-heater was not working, it has been repaired, I used it for the first time this morning and the car battery was dead when I came to start engine!
Apparently this is the fault of the blackvue, although the black vue has one of those battery cut off devices to stop it drawing too much power.
The blackvue has been fine for 3 months or so until I used the pre-heater.......
Any ideas?
Post #372726 Fri Feb 08 2013 2:29pm
Solution!
I'll take the backvue off you for £50 Mr. Green
Problemo solved...(I thank you) RRS gone
Post #372729 Fri Feb 08 2013 2:40pm
overfinchred
Re: Seems I must choose between Blackvue and Pre-Heater!
Any ideas?
What is a blackvue? “One good thing about music, when it hits you, you feel no pain.”
Current RRS Overfinch TDV8, Nissan Skyline R34 GTT, 1958 VW Splitscreen camper, 1961 VW Splitscreen Double cab pickup( now gone), Fiat 500
Gone -BMW X5 and X6, Jaguar XF, Chrysler 300c, Nissan Figaro, Nisan 350z,BMW 3 series, Merc 220d, various Fords, Mini Cooper, 3 old shape mini's, Ford Capri
Post #372731 Fri Feb 08 2013 2:45pm
Constant cam that records whenever the ignition is on.. Mr. Green
 RRS gone
Post #372732 Fri Feb 08 2013 2:51pm
maybe the blackvue is set too sensitive and recording all night instead on going in the standby, maybe try lowering the settings
also check out the blackvue info on disco3, Wiggs and other users have a fair bit of experiance with what firmware works and doesn't, im sure they have solved this issue
Post #372734 Fri Feb 08 2013 2:59pm
Jonny Fresh
This was sorted by a new battery fitted by LR Assist Thumbs Up Thumbs Up Thumbs Up
Post #374105 Wed Feb 20 2013 11:46am
muddywheels
Milk Float Man
I have the battery saver and RRS always starts but on cold mornings when heated screens and pre heater on the blackvue keeps shutting down and restarting until I knock off the heated screens Evil or Very Mad
Presume the load is knocking battery below 11.8v and shutting down bv - anyone else got this problem or is my battery on the way out Rolling Eyes Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #374213 Thu Feb 21 2013 11:53am
