Home > General > Fan Delay... Help Please
PauloAmore
Scotland
My fan (screen blower) fails to start up for a few minutes in the morning...
LED fan speed indicators glow orange... Wait a few minutes, then whoosh... full speed....
- maybe happens when particularly cold.
Its a MY05.
With thanks in advance
Puaul 2022 P440e AB
Post #372394 Tue Feb 05 2013 11:13pm
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Mine does the same with the air con set. I just assumed it was clever enough to wait for the engine to warm up enough to blow warm air not cold.
Nik 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #372410 Wed Feb 06 2013 8:19am
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
Same here unless I put it on defrost mode. Although I've also had the fan continue to run after the ignition was off and tapped the relay under the bonnet which stopped it immediately. Maybe the two are related and the relay is struggling to switch itself on or off Confused
"Roads ? Where we're going there are no roads." Back to the future.
Post #372412 Wed Feb 06 2013 10:06am
I believe it's a feature to stop the car being pumped full of cold air until the heaters are up to temperature. Thumbs Up
I had the same on my Audi's and BMW's - logical idea really Cool ON THE WAY: BMW F21 M140i
Post #372414 Wed Feb 06 2013 10:22am
PauloAmore
Scotland
I'm sure it's a fault. Can last 3 or 4 minutes. 2022 P440e AB
Post #372812 Sat Feb 09 2013 8:30am
Nik
So can mine when it's really cold out there.
Take it in to LR if you're still unsure.
Nik
 2015 Golf R DSG
Post #372814 Sat Feb 09 2013 8:41am
PauloAmore
Scotland
Bump....
Guys - this is definitely a fault. There is no delay feature.
- just posting this for future forum reference.
Strathearn Engineering replaced the Final Stage Resistor in the passenger footwell.
- all good. Instant fan blowing.
Cheap fix too. Part was around £50 + vat. Less than £100 inc labour. 2022 P440e AB
Post #395932 Mon Sep 23 2013 8:57pm
PegoVix
Hi guys, i have the same problems particularly when it's colder, I replaced the final stage resistor last week and the problem still persists.
does anybody have any more thoughts on this.
Post #452466 Fri Feb 13 2015 10:18pm
Disco_Mikey
Try swapping the relay with another. Fairly common problem Thumbs Up
Post #452467 Fri Feb 13 2015 10:37pm
PegoVix
Thank very much for the relay advice, took it out the other day to get a replacement but couldn't get one so put old one back in and since then it's worked fine with no faults.
Post #453095 Fri Feb 20 2015 8:26am
Lost for Words
Any standard 4 pin relay would do the trick. How long it lasts, of course, will be quality dependant. Thumbs Up Visiting from DISCO3.CO.UK
Post #453106 Fri Feb 20 2015 9:43am
