Home > Technical > Trouble Starting???!!!!!
Tiny Timmy
Im after some help, my 2005 sport when its cold (sub zero only) struggles to start. Could this be down to the EGR valves at all?? As I have had the Glow plugs tested and are all ok..........................TT
Post #371864 Fri Feb 01 2013 12:35pm
Not your EGRs.
On a cold start, it'll make no difference if they're open or shut. RRS gone
Post #371877 Fri Feb 01 2013 2:54pm
Tiny Timmy
Thanks, so if the Glow plugs were tested when it wasnt below zero, would they show all working ok???.........TT
Post #371887 Fri Feb 01 2013 4:10pm
best way to test this is to turn on the ignition, wait for the glow plug light to go out, then immediatly turn off the ignition and back on again...wait for the glow plug to go out again then turn it over. RRS gone
Post #371888 Fri Feb 01 2013 4:14pm
Tiny Timmy
Yeah I do that, but its not any better then after about 30 seconds it starts and then is fine ??? Question Neutral Neutral ...TT
Post #371889 Fri Feb 01 2013 4:20pm
fuel pressure issue? RRS gone
Post #371891 Fri Feb 01 2013 4:26pm
Tiny Timmy
Ok Ill look into that. The main reason I ask because Ive been told it maybe Glow plugs and if it is it will be £2500!!!!!! because you cant get the things out without drilling etc etc, and if it comes to that I just cannot afford it and it will have to go, which breaks my heart!!................TT
Post #371899 Fri Feb 01 2013 4:57pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
It may have a leaking injector leading to low pressure, you can have a leak test done which will highlight this problem. If so it will be a new injector. You need to get it done if you don't it could fail completely and leave you stranded.
Post #371900 Fri Feb 01 2013 5:09pm
Bodsy
Site Sponsor
timmy, re the glowplugs, yes they can be incredibly stuck, but doused for several days before with plusgas or similar and then removed with the correct LR tool which stops any twisting, they should come out fine.
was it an indi that said 2k....? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371901 Fri Feb 01 2013 5:17pm
Tiny Timmy
Ok another thing to look at, It was an independent 4x4 specialist who said definitely glow plugs and £2500 to exchange them..............TT
Post #371906 Fri Feb 01 2013 5:50pm
