Home > Maintenance & Modifications > Car going mad after changing the altinator
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Just got my altinator replaced and now having som wierd stuff going on....
Yesterday I started the car fine but then the radio / navi started to turn itself on and off and I could heard a typical electicitysound going up and down.
I also got the yellow warning light on adaptive lights Shocked . After 1 min the radion got back to normal and after 30 min the light in dash cleared ........ had about 13.5 to 14.00 voltage with the engine on and at several speeds .....
Today I started the car with no problems, but again radio / navi going mad for about 10 sec and yellow parking lights came up in dash Shocked .... Everything was gone after 10 sec. 14.5v voltage on the way to home. Thumbs Up
Anybody have any suggestions here?? Is it the battery that is struggling or is it the job my dealer did when changing the alternator? Purhaps charging the battery may work?? new battery?? RRS 2006 2.7 HSE
Post #371821 Fri Feb 01 2013 9:27am
Bodsy
Site Sponsor
if you havent charged the battery (on a proper charge) since having the alternator replaced, then that would be the first thing.
Alternator should be kicking out between 14 and 15.5v should be nearer the higher end of the scale if the battery is not charged. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371822 Fri Feb 01 2013 9:40am
RRSNorway
Thanks!
I just bought a defa smartcharger: http://www.defa.com/en/automotive/powersys...artcharge/
Will give it a go later Smile
Hope it give the battery some new life ( It was changed 3 mnd ago so should be all right if the altinator diden't f... it up when it broke down...) RRS 2006 2.7 HSE
Post #371824 Fri Feb 01 2013 9:53am
sherlock
2008 Range Rover Sport TDV8 HSE Santorini Black
Just had a quick look and looks impressive and well designed. Has anyone used them and know where they can be purchased from and how much? TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
20" HST alloys, Privacy glass, Side steps, Xenon Adaptive Lighting, Adaptive cruise control
Post #371829 Fri Feb 01 2013 10:45am
RRSNorway
I have used it before. Works very well. Plug and play and gives you an indicator of the battery level in a nice white LED. Turns it self on and off Smile Cost £60ish here in Norway.
Haven't used the 14.7V button yet because I dont know if my battery can take it.... RRS 2006 2.7 HSE
Post #371832 Fri Feb 01 2013 11:03am
sherlock
Thanks - struggling to find a UK supplier at the moment Big Cry TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Post #371833 Fri Feb 01 2013 11:15am
RRSNorway
The car worked fine for 1 day but today at -4 c I started the car the interiorlights and radio started going on and of like a puls. Got the adapitive lights fail on and then the parking break.....after a 6 min drive the car got warm and when coming back from the store everything was good again....Strange!!!! RRS 2006 2.7 HSE
Post #371980 Sat Feb 02 2013 6:10pm
TST717
Scotland
Your battery will take the 14.7 v charge no problem, the charger will sense the battery voltage and set the current to suit the status of the battery.It sounds like you may have some other type of fault somewhere unless of course the voltage regulator on your new alternator is dodgy......is it a genuine LR Alternnator? TDV8 HSE....Gone but not forgotten ....class act
Cayenne S diesel.....850n/m....385bhp....the danglies ...
Post #372026 Sun Feb 03 2013 3:12am
RRSNorway
I think its a genuine LR alternator...after a test I could see the voltage was about 15.8 and down to 13.0V
It lasts for 1 min and then everything is fine again....could it be the alternator that gives the wrong Volt or the battery?
You can hear snapping sounds from the battery area when it starts to go crasy before its goes back to normal 14.5 V RRS 2006 2.7 HSE
Post #372067 Sun Feb 03 2013 4:02pm
RRSNorway
Started the car today and got a voltage fron 13,5 to 16,5 Shocked damn high!!!
Must be the battery I think now. Went back to 14,5 after 30 sec. RRS 2006 2.7 HSE
Post #372189 Mon Feb 04 2013 4:47pm
