![]() | Home > Technical > Have I made an Expensive Mistake? |
RossM Member Since: 27 Aug 2012 Location: Poulton-Le-Fylde, Lancashire Posts: 80 ![]() ![]() ![]() |
My 22" Stormers arrived yesterday and wrapped up in the excitement I decided to fit them straight to the car in the pouring rain which happened to get even harder just as I had the last wheel to do, the rear left! So placing the trolley jack under the chassis at the jacking point I preceded to jack her up until suddenly a slip and a bang! Seems I'd not got the jack under the chassis enough and the bang was the jack cracking into the box that covers the suspension compressor. I now have a working but noisy compressor and a small handful of broken box!
You've almost certainly cracked the compressor mount. You may be able to pick one up second hand from a breakers,otherwise istr they're about �90ish
Is it easy to remove the box/mount? And what it's technical name? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
sherlock Member Since: 29 Dec 2011 Location: Burscough Posts: 690 ![]() ![]() |
Ditto, mine was damaged from the previous owner but decided to change the compressor as well as the unit would click away until fully charged. Cost me �450 TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Sherlock, did you do the work yourself or was that garage price? If DIY was it an easy job? 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Garage price but an independent LR garage in leyland, Lancs. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Thanks, I've used them before for my Freelander 2. Hopefully I can do it myself for just the cost of parts 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Am sure you can. Provided you have tools and can lift your car you should be ok. TDV8 HSE, Remap (+45 BHP + 100 Nm), Taylored sport exhaust system by Pipe Werx
Replacement compressor mount and box in the post. Hopefully get round to fitting next weekend. 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Cheers for that sound advice Panda, fingers crossed I do't make the same mistake twice! 2007 Range Rover Sport TDV6 HSE- Cairns Blue with 22" Stormers |
Mike767 Member Since: 31 Aug 2012 Location: Cheshire Posts: 19 ![]() ![]() ![]() |
I needed to change the compressor on my D3. Depending on your vehicles age, it might be worth making sure that you have new "fixing clips" available. I think there are three that slot into the chassis that the mounting bracket bolts into. Mine were all corroded and fell to pieces. They would cost peanuts but it will stop you in your tracks if you need to replace them due to corrosion.
Wise words mike, been and ordered the relevant fixings today ready for the job.
Quick reply-off to work.
