Home > General > spare wheel anti theft
range17
Made and fitted this today Thumbs Up
 zx12r
bmw gs1200 adventure
defender 90 off roader
Post #370971 Fri Jan 25 2013 6:53pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Loving your work! I was going to make my own but by the time I'd have got it powder coated it would have cost me as much as buying one Rolling Eyes
Good effort! Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #370972 Fri Jan 25 2013 6:58pm
range17
Cheers ,i just gave it a good coating of 2pack black gloss then lined it with 6mm rubber sheet so it doesnt rub on the tyre/wheel .
Time will tell if the paint is good enough under there . zx12r
Post #370974 Fri Jan 25 2013 7:03pm
Bob.
Good piece of work Thumbs Up
If you have sealed the plate against the tyre with the rubber sheet it would be worth considering adding a drain hole at the lowest point. It is suprising how much water will get entrained and build up in there otherwise - even without wading.
Post #370992 Fri Jan 25 2013 10:04pm
range17
Should be ok to be honest as the rubber does not seal that tight Thumbs Up zx12r
Post #371003 Fri Jan 25 2013 11:16pm
jim4244
England 2013 Range Rover Sport SDV6 HSE Santorini Black
Looks good Thumbs Up
Jim
Post #371321 Tue Jan 29 2013 5:34am
Off Topic
Jim
It's the lesser spotted Jim.....where have you been, not seen you on here much Question Thumbs Up ON THE WAY: BMW F21 M140i
Post #371334 Tue Jan 29 2013 9:39am
range17
Beancounter_74 wrote:
Off Topic
Jim
Question Thumbs Up
Never mind "Jim " what about my wheel thingy Big Cry Big Cry Big Cry zx12r
Post #371382 Tue Jan 29 2013 1:57pm
Rolling with laughter Looks very good Thumbs Up ON THE WAY: BMW F21 M140i
Post #371384 Tue Jan 29 2013 2:19pm
range17
Cheers ,tissues away Thumbs Up zx12r
Post #371389 Tue Jan 29 2013 2:45pm
