Home > Maintenance & Modifications > How do you remove the compressor inlet and exhaust pipes?
Mitchmx
I been following the link to service the suspension compressor but I can't remove the inlet and exhaust pipes. Not the ones with the blue and red clips it has brass inserts on the end. It says to cut the pipes but if I do that I won't be able to put them back on.
Anybody removed, serviced and refitted the same compressor that could help?
Thanks in advance Thumbs Up
Post #371162 Sun Jan 27 2013 11:27pm
mrfrog
United Kingdom 2005 Range Rover Sport Supercharged Vesuvius Orange
I think someone said that the connectors on the old compressors weren't push-fit and the only solution was to cut pipes.
I've ended up cutting mine after trying far too long to get them off otherwise, getting some push-fit connectors and lengths of plastic pipe of right dimension (2 or 3 different sizes needed irrc) from a hydraulics place and all good.
"Roads ? Where we're going there are no roads." Back to the future.
Post #371230 Mon Jan 28 2013 5:40pm
Mitchmx
Ok thanks for the reply
Don't suppose you know type of connectors I'm going to have to get. Question
Post #371248 Mon Jan 28 2013 7:45pm
Bodsy
Site Sponsor
I carry some 6, 8 and 10mm connectors and pipe.
Ill try to dig out some links. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #371252 Mon Jan 28 2013 8:20pm
mrfrog
From memory (no guarantee whatsoever), I got one 4mm and one and 6mm straight (compressor side towards the car) and an elbow in 8mm (rear of the compressor), plus short lengths of 4, 6 and 8mm pipe.
To be on the safe side, I took the compressor and cut pipes to the shop so they could measure up for sure.
Post #371253 Mon Jan 28 2013 8:21pm
mrfrog
oops, I'd follow Bodsy's numbers, not mine Embarassed
Post #371255 Mon Jan 28 2013 8:21pm
Bodsy
Site Sponsor
This is where I got my connectors and pipe.
Look at this on eBay:
8mm Push In Nylon Tube Hose Connector Joiner Air Line
http://bit.ly/VsdZzB
Hope the link works, otherwise its eBay number eBay Item No. 260720954273 (and others) Bodsys Brake Bible
See it HERE
Post #371260 Mon Jan 28 2013 8:33pm
Mitchmx
Thanks guys.
That be great if you could have a look bodsy. Thumbs Up
Post #371261 Mon Jan 28 2013 8:35pm
Mitchmx
Yea it worked thanks.
Ill get some ordered up.
I just want to service the compressor to see it this venting decreasing from gallery error goes.
I've fitted new sensors checked the wires so this must be the only thing it can be.
Post #371265 Mon Jan 28 2013 8:41pm
mrfrog
I had the venting from gallery error on mine, a new compressor sorted it. Some have cleaned or replaced the drier, although I am not sure you can get it separately any more. Taken my drier apart and would never have managed to put it back together Laughing
Post #371536 Wed Jan 30 2013 11:17am
Bodsy
Site Sponsor
You can still get the drier unit, it's about £70 from LR.
You can take the top off it and refill with fresh silica gel as well. Just measure same amount back in as came out (or thereabouts) You can also redry in the oven if it's not too powdery.
I have some silica gel left from a batch I bought if anyone needs some. £5.50 posted Thumbs Up
It's enough to replace the gel that you remove if you take the top off the drier.
Don't forget Mitch that there is a filter behind the left hand boot panel that is the air filter for the compressor and occasionally, that can also get blocked by dust, although not very common, it's something to check out as well. Bodsys Brake Bible
See it HERE
Post #371539 Wed Jan 30 2013 11:36am
Mitchmx
Ill check that bodsy thanks.
I got the 6mm pipe connector today just waiting for the other two which should be here tomorrow and then ill have the compressor off.
Post #371551 Wed Jan 30 2013 1:23pm
Mitchmx
Well today was the day. I removed and stripped the compressor. The gel balls were white so put them in the oven till they were blue again. Rebuilt it, cleared the fault codes and it worked fine with no error
Till I drove home, half way home. Ding!!!
Fault code it tomorrow and see what it's saying now. Mad
Post #371987 Sat Feb 02 2013 6:33pm
mrfrog
Have you changed the relay to the compressor (in engine bay) ? It usually gets changed along with the compressor. It's a cheap enough replacement to try.
Besides the drier, there could be some clogging in other places/filters that is stopping air releasing too.
Well done for drying the dryer Bow down
Post #371989 Sat Feb 02 2013 6:46pm
Mitchmx
No I didn't to be honest. Ill grab one and try that before pulling the compressor off again.
I can see me handing over 400 quid here for a new compressor Big Cry
Post #371996 Sat Feb 02 2013 7:17pm
