![]() | Home > Maintenance & Modifications > How do you remove the compressor inlet and exhaust pipes? |
Mitchmx Member Since: 22 Jul 2012 Location: Bristol Posts: 156 ![]() ![]() |
I been following the link to service the suspension compressor but I can't remove the inlet and exhaust pipes. Not the ones with the blue and red clips it has brass inserts on the end. It says to cut the pipes but if I do that I won't be able to put them back on.
Ok thanks for the reply
I carry some 6, 8 and 10mm connectors and pipe.
mrfrog Member Since: 07 Aug 2012 Location: Berkshire Posts: 285 ![]() ![]() ![]() |
From memory (no guarantee whatsoever), I got one 4mm and one and 6mm straight (compressor side towards the car) and an elbow in 8mm (rear of the compressor), plus short lengths of 4, 6 and 8mm pipe.
oops, I'd follow Bodsy's numbers, not mine ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
This is where I got my connectors and pipe.
Thanks guys.
Yea it worked thanks.
I had the venting from gallery error on mine, a new compressor sorted it. Some have cleaned or replaced the drier, although I am not sure you can get it separately any more. Taken my drier apart and would never have managed to put it back together ![]() ![]() "Roads ? Where we're going there are no roads." Back to the future. |
You can still get the drier unit, it's about £70 from LR.
Ill check that bodsy thanks.
Well today was the day. I removed and stripped the compressor. The gel balls were white so put them in the oven till they were blue again. Rebuilt it, cleared the fault codes and it worked fine with no error
Have you changed the relay to the compressor (in engine bay) ? It usually gets changed along with the compressor. It's a cheap enough replacement to try.
No I didn't to be honest. Ill grab one and try that before pulling the compressor off again.
