Home > Technical > Help please - SRS Light On
GAC23
2006 Range Rover Sport TDV6 HSE Zermatt Silver
My first post and I'm asking for help!
Got a 56-plate TDV6.
Two weeks ago had the 'hdc fault, transmission failure' message - thankfully that was just the brake switch - phew!
Yesterday the SRS light didn't go out when I started the car.
And it's still not going out. After the 'system test' it goes out for a split second then comes back on again.
Any ideas? All help very gratefully received.
Thanks in advance,
G.
Post #369326 Mon Jan 14 2013 2:14pm
Hi and welcome
and
I've no idea... Thumbs Up
Obviously an airbag issue... needs checking by a dealer if you ask me RRS gone
Post #369330 Mon Jan 14 2013 2:42pm
Martin
Site Administrator & Owner
You need to get it on a fault code reader really - it could be an airbag fault or something silly like a broken or damaged wire under a seat. Like this site? Buy some RRSPORT goodies to show your support!
Post #369331 Mon Jan 14 2013 2:43pm
GAC23
Thank you and thank you.
I'm hoping that like the 'hdc fault' it's something silly, simple and cheap.
And not a wallet burner.
I had read that a low battery could do it.
And that the sat nav screen dimming when you start the car is a sign of a low battery.
Or is that all nonsense?
Post #369334 Mon Jan 14 2013 2:45pm
Not at all, battery/alternator have been the cause of many a problem, as have failed brake bulbs and brake switches. Shocked
All relatively easy to solve so worth checking as a matter of course before you venture deeper into prognosis. Thumbs Up ON THE WAY: BMW F21 M140i
Post #369339 Mon Jan 14 2013 3:01pm
GAC23
Is there a way to reset the fault warning?
I just want to see if it comes back on again.
And - you can tell I'm new to this can't you - what's a good fault code reader to get?
Post #369429 Tue Jan 15 2013 10:24am
no mate.
You can buy them, but they are not cheap.
cheaper to get a diagnostic from your dealer. RRS gone
Post #369434 Tue Jan 15 2013 10:33am
GAC23
Ok, understood. Thank you.
Post #369435 Tue Jan 15 2013 10:38am
worth checking out the for sale on here (and disco3) websites though.
2nd hand ones come up periodically but do get snapped up pretty quick Thumbs Up RRS gone
Post #369436 Tue Jan 15 2013 10:41am
GAC23
Thanks. I will.
Post #369438 Tue Jan 15 2013 11:08am
marco247
United Kingdom 2009 Range Rover Sport Supercharged HST Java Black
Unless your in East Yorkshire then you can come to mine and i will hook it up for you FOC Cool
Post #369467 Tue Jan 15 2013 4:47pm
GAC23
Thank you.
But sadly I'm not.
I've read quite a bit about cables under the seats having dodgy connectors that can cause this.
My local dealer also said that could be the problem.
I'm going to have a nose ...
Post #369471 Tue Jan 15 2013 4:52pm
GAC23
Don't know if this is all connected but ...
When I started the car this morning I had a both heated screens on, the fan blowing hard , drivers heated seat and radio.
When I pressed the brake to put it into reverse I got a suspension fault (only normal allowed).
Turned the ignition off and on again, all ok.
But does that mean I have a dying battery and it's that causing my srs light problem?
Post #369617 Wed Jan 16 2013 2:57pm
marco247
"When I pressed the brake to put it into reverse I got a suspension fault "
Having had a very similar experience but with more warning lights come on,I would change the brake light switch,can get them for about 12 quid and it rids gremlins like you wouldnt believe! If anything is happening to said warning lights when your foot touches the brake......it will be the lovely little switch mechanism thats sparking gremlins to your OBC.
Post #370497 Tue Jan 22 2013 2:28pm
GAC23
Looks like it was a dodgy connection under the seat.
All sorted now - phew.
Over the last few days when it's been really cold I've had another 'Suspension Fault'.
Got it when running front & rear heated screens, the heated seats.
My guess was the battery and it was. Which is kind of good I guess - cheaper than the suspension anyway Smile
Thanks to all for their help.
Post #370499 Tue Jan 22 2013 2:41pm
