![]() | Home > Technical > Help please - SRS Light On |
Hi and welcome
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
You need to get it on a fault code reader really - it could be an airbag fault or something silly like a broken or damaged wire under a seat. Like this site? Buy some RRSPORT goodies to show your support! |
GAC23 Member Since: 14 Jan 2013 Location: UK Posts: 16 ![]() ![]() |
Thank you and thank you.
Not at all, battery/alternator have been the cause of many a problem, as have failed brake bulbs and brake switches. |
Is there a way to reset the fault warning?
no mate.
Ok, understood. Thank you. |
worth checking out the for sale on here (and disco3) websites though.
Thanks. I will. |
marco247 Member Since: 25 Apr 2012 Location: Hull Posts: 57 ![]() ![]() ![]() |
Unless your in East Yorkshire then you can come to mine and i will hook it up for you FOC |
Thank you. But sadly I'm not. I've read quite a bit about cables under the seats having dodgy connectors that can cause this. My local dealer also said that could be the problem. I'm going to have a nose ... |
Don't know if this is all connected but ...
"When I pressed the brake to put it into reverse I got a suspension fault "
Looks like it was a dodgy connection under the seat.
