Home > Technical > Suspension Warning Light
JoeRRS
I know this subject has been brought up loads but got a call from the mrs last night saying suspension warning light coming on I cant imagine it being the compressor as I got it replaced about this time last year as was told it was on its way out. Would the temperature effect it in anyway? Its been sitting on the drive for a couple of days with only 1 or 2 short trip 5 miles or so. Im offshore at the moment so cant do too much with it untill I get back.
Post #370068 Sat Jan 19 2013 8:36am
RRS_PAT
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I have the same thing on mine Sad
I took it back to the dealer and they said there was a leak somewhere. Apparently this can be difficult (expensive) to track down.
I was advised to check after it has sat for a long time - at least overnight- to see if one wheel is lower than the other.
Search for my posts as I posted the same question and there was an answer with a great link where someone had taken apart some of the air suspension to fix.
Pat 2011 Autobiography Santorini Black
Post #370071 Sat Jan 19 2013 9:09am
jakeob
England 2007 Range Rover Sport TDV8 HST Java Black
Mine light came on a couple of times last week,,, just turned the ignition on/off and it went off..
I,m still a bit worried as its slow to raise a the front and some times a bit jerky
Post #370073 Sat Jan 19 2013 9:18am
JoeRRS
I will get it booked in for Tuesday when I get back.
My mrs turned the ignition off and back on again and it seems to have reset it.
Not had any problems with the rate that is lowers raises so im looking its not a big problem.
Anyone know how long a warrenty you get from LR dealers on work they have done?
Post #370076 Sat Jan 19 2013 9:28am
Melbop
United Kingdom 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi Joe,
I'm experiencing similar problem at present.
My suspension does drop on the inside front leg.
Booked it in at Duckworths yesterday 13:30. Took one hour to establish - couldnt find leak thinks its bag- common perishable
fault they said? Would be reported to Landrover under warranty .
10am today Landrover gave ok to use" REPAIR KIT" . Anyone know if that's a sticking plaster or a lump of chewy?
I must say I'm bloody impressed at speed it took to sort.
What worries me though , how long will repair last???
________________________________________________________
TD v8 fine specimen ! Thumbs Up
Post #370131 Sat Jan 19 2013 4:47pm
JoeRRS
So update from today is suspension compressor is bust but seeing that I only got it replaced by LR main dealer 9 months ago they are going to replace it free of charge. Downside is that I have been told that the driveshaft is bust and needs replacing has any one else had to do this there looking to charge me around 600 pound.
Post #370557 Tue Jan 22 2013 7:13pm
