Home > Maintenance & Modifications > My front and rear lights get foggy. How to tackle that? |
Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796 |
Handbook will tell you it's 'normal'
Fri Jan 18 2013 3:53pm |
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 401 |
Well. ok. If it is normal then its one less problem. 91 BMW 850CSI |
Fri Jan 18 2013 5:45pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
It's normal. The light units have rubber breather pipes on the back so they should clear with use (heat from the headlight obviouslhy helps). 2012 SDV6 - it's missing a couple of cylinders
Fri Jan 18 2013 5:53pm |
