![]() | Home > Maintenance & Modifications > My front and rear lights get foggy. How to tackle that? |
Handbook will tell you it's 'normal'
Fatandre Member Since: 05 Oct 2009 Location: Reykjavík Posts: 402 ![]() ![]() ![]() |
Well. ok. If it is normal then its one less problem. 91 BMW 850CSI |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9048 ![]() ![]() ![]() |
It's normal. The light units have rubber breather pipes on the back so they should clear with use (heat from the headlight obviouslhy helps). 2012 SDV6 - it's missing a couple of cylinders
