Home > Maintenance & Modifications > Feature Enabling
OldandTired
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Firenze Red
Feature Enabling
Hi
Does anyone know if the High Beam assist and the ability to see the reverse path trajectory in the rear view camera can be enabled by tweaking the CCF? I have a tow pack on my car and thought that the rear view camera would show the guidelines bending as the steering was moved but apparently not Crying or Very sad
Am due to get the park heater/timed climate enabled shortly so if possible would be good to get the others done at the same time.
Anyone know what can be turned on in a MY12 (that's worth having)?
Thanks, Paul RRS Autobiography MY14 Firenze Red
RRS HSE Lux MY12, Sumatra Black/Ivory Privacy, Towpack and remote heater, Gone
RRS HSE Orkney Grey MY11, Gone after one month
RRS HSE 56 Java Black, Gone
Post #368899 Thu Jan 10 2013 2:22pm
I aske da similar question, but i think the consensus on the sterring lines was a 'no' unless you have the surround camera pack. Sad
Mike (mse) on here should be able to comment re High Bean assist, but i guess you would need some hardware too in order for that to work. Confused ON THE WAY: BMW F21 M140i
Post #368902 Thu Jan 10 2013 2:25pm
OldandTired
Many thanks. Makes me wonder why they bothered putting the lines on the camera image (unless they thought we'd all only ever reverse in straight lines Confused )
Hey ho another LR idiosyncrasy I guess. Appreciate your response. Best, Paul RRS Autobiography MY14 Firenze Red
Post #368908 Thu Jan 10 2013 2:37pm
My thoughts exactly, it gives a rough indication, but thats about the only use.
The problem is that there aren't too many people with the software to change the system for MY12 cars outside of dealerships, I guess as more people get hold of it, then someone may find a solution.
If you do hear of a way, do let us know. Thumbs Up ON THE WAY: BMW F21 M140i
Post #368909 Thu Jan 10 2013 2:40pm
mlines
I seem to recall that the "lines bending" on the reversing screen only occurs when you have the multiple camera set up which gives the trailer assist function.
The standard single camera set up only has fixed tramlines
Martin 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit
Post #368920 Thu Jan 10 2013 3:25pm
