Home > eBay & Bargain Spots > Interior led upgrade
Page 2 of 3 <123>
fkarim
1860Gavin wrote:
Good luck with changing the glove box bulb. Advice is do this one last as it may test your patients !!! Big Cry
It makes it easier to do the glove box light if you take the unit out using this guide rather than attempting to replace the bulb in-place.
Post #368732 Wed Jan 09 2013 1:49pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Luckily there's a helpful guide (link is in the definitive 'how to' thread in the technical section)
http://www.rrsport.co.uk/forum/topic12849.html
Edit: Fkarim beat me to it while I was on the phone. Rolling with laughter
Post #368734 Wed Jan 09 2013 1:57pm
1860Gavin
United Kingdom 2006 Range Rover Sport Supercharged Zermatt Silver
I did use the guide but the part broke whilst removing. But not to worry is was less tan a tenner to replace !!!! And surprise surprise another Ford part. Smile
Post #368743 Wed Jan 09 2013 3:00pm
Kimmea
Scotland 2013 Range Rover Sport SDV6 HSE Fuji White
Any ideas on how to change the Side lights as I had a quick look and quickly closed the bonnet again when I thought I may need some tools.
Post #374167 Wed Feb 20 2013 9:02pm
MisterAdam
Piece of cake pal, the headlight units have got a round black cover about the size of a mug/glass/cup coaster, unscrew that then feel about for the sidelight, pop that out, swap bulb over, turn the sidelight on to check you've got the LED in the right way (they generally only work one day, if it doesnt work then turn it 180 degree's and put it back in) and in true Haynes fashion "refitting is the reverse of removal" Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Previous: Mercedes CLS, BMW 330cd M sport, Nissan 200sx, Impreza STi, EP3 Civic Type R
Post #374195 Thu Feb 21 2013 8:54am
kav1187
You'll have to remove the headlight to get to the sidelight cover. Follow this vid on how to remove headlight, it's straight forward.
Kav Thumbs Up Want to do a DIY job on your car? Check out the definitive 'how to' thread in the technical section Thumbs Up
http://rrsport.co.uk/forum/topic28424.html
Post #374199 Thu Feb 21 2013 9:38am
MisterAdam
I didn't have to remove the headlight to get to the sidelight in order to change the bulb, doing that seem's a little extreme when there's a removable access panel on the back of the headlight unit Shocked Current: 06 RR Sport HSE TDV6, Bonatti grey, black leather. Defender 90 pick up. Vito 110cdi
Post #374204 Thu Feb 21 2013 10:15am
big pimp
I'm removing most of the LEDs inside. Think it looks too blue-y and the normal bulbs looked better IMO
I'll keep the LEDs in the driver and passenger overhead switched, but I'm gonna replace all the others back MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #374224 Thu Feb 21 2013 12:49pm
Laughing I'm in a similar camp big pimp and recently changed mine patially back too, although I've changed the overhead ones back to standard and left the LED's in the door puddle lights and footwell/boot. ON THE WAY: BMW F21 M140i
Post #374226 Thu Feb 21 2013 12:59pm
I only changed the four door puddle lights internally. It gives a better view of what's on the ground before you step out. I think LEDs would be too harsh for the rest of the interior fittings.
I have fitted LEDs to the number plate and sidelights though because, again, I think they improve visibility - particularly the rear number plate. It also has a useful side effect of lighting the ground immediatly behind the vehicle - useful if one has parked and wants to go to the boot and the engine / lights are on. 2012 SDV6 - it's missing a couple of cylinders
Post #374243 Thu Feb 21 2013 3:34pm
The only way I could get to the panel was to remove the whole headlight unit from the vehicle - the panel is at the bottom of the unit. 2012 SDV6 - it's missing a couple of cylinders
Post #374244 Thu Feb 21 2013 3:35pm
Yep, forgot about the numberplate ones, I've left those as LED too Thumbs Up
Can't make my mind up on the side lights..... Confused ON THE WAY: BMW F21 M140i
Post #374245 Thu Feb 21 2013 3:42pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Anyone know why the sidelights always looks blueish while the same bulb looks white in the interior??
Do the reflectors make them blueish??
If someone got the perfect xenonmatch let me know;) RRS 2006 2.7 HSE
Post #374306 Thu Feb 21 2013 11:40pm
The interior fittings have white plastic in them to reflect the light. The sidelights are mirrored. I can only assume that the white plastic takes the edge off of the blue tint whereas the mirror finish just reflects the blue. 2012 SDV6 - it's missing a couple of cylinders
Post #374310 Fri Feb 22 2013 12:01am
Kimmea
Thanks guys
Post #374311 Fri Feb 22 2013 12:02am
Page 2 of 3 <123>
