Home > General > Are you always in Drive?
Do you put your car in N when stopped?
Yes - I put it into N when stopped
26%
 26%  [13]
No - I leave it in D
73%
 73%  [36]
Total Votes: 49
Nik
United Kingdom 2008 Range Rover Sport TDV6 HSE Stornoway Grey
D for me unless I'm going to be stationary for a while.
Nik 2015 Golf R DSG
Gone 2013 Mercedes C220 CDi AMG Sport Plus
Gone 2008 2.7 RRS HSE
Post #368430 Sat Jan 05 2013 8:55am
Gerico
^^^^ Same here. I know I really shouldn't but you hear of issues with the EPB and I'm just a bit lazy to be honest.
As for the driving test you don't even have to apply the handbrake at a stop sign anymore. Days gone by you did fail for leaving your foot on the brake and dazzling those behind you. Not anymore, the test is getting easier and easier. You only get to reverse once and if you go the wrong way on the 'independant drive' section it doesn't matter so long as you do it safely! Shocked
Richard
Oh and at the risk of tempting fate I've had no issues with car it's been remarkably reliable.......
Post #368434 Sat Jan 05 2013 9:53am
Bomber H
This is the first auto I've owned, and I spend most if the time popping it into P as it doesn't require the EPB to be applied. However I'm beginning to get into the habit of popping it in to N and using the EPB.
I've always been annoyed by auto drivers in front sitting at lights with their foot on the brake, so I'm trying not to be that person, unless I know I'm only going to be stopped for a short time. 2016 VW Golf GTD DSG
2007 Exige S British GT SE
Gone : 2011 3.0TDV6 HSE, Stornoway Grey, Ivory, Piano Black Trim, Paddleshift, Privacy Glass, Side Steps, Mud Flaps, Heated Steering Wheel, Timed Climate & Remote Park Heating Smile
Post #368448 Sat Jan 05 2013 1:38pm
Mike_S
D for me, unless I'm stopped for a while. I do use the EPB frequently though as I was told with my Jag that not using it caused things to seize
Post #368635 Tue Jan 08 2013 10:37am
SkyWalker
Netherlands 2005 Range Rover Sport TDV6 HSE Buckingham Blue
Shocked Rolling with laughter
The parking brake is, as the name may indicate, used for when the car is parked.
Enroute, D is the correct mode.
Shifting between D and N or P while enroute is not required and causes unnesesary wear and tare on the plates. SW
Sometimes it is not enough to do our best;
sometimes we must do what is required.
Adriatic Blue 2005 RRS HSE 2.7 TDV6
Now: 2016 RRS HSE DYNAMIC 3.0 TDV6
Post #368637 Tue Jan 08 2013 10:57am
muddywheels
Milk Float Man
I put it in N if stopped more than a few seconds and EPB on Thumbs Up
Was advised sitting with foot on brake can warp discs if they are hot and sitting in D puts strain on torque converter and can fail over time Confused Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #368638 Tue Jan 08 2013 11:03am
In D for me, I may apply the EPB if I'm sat for a while at a particular set of light and feeling curteous to the driver behind, but in 95% of the cases, I stay in D with foot on the brake. ON THE WAY: BMW F21 M140i
Post #368640 Tue Jan 08 2013 11:28am
