Home > Technical > heavy steering - UV joint ceased
Hulmey14
just after some advice
steering on MY08 RRS has gone heavy - contacted the AA (which I have breakdown and repair cover with) and they suspected the power steering pump
subsequently took it to local landrover garage who have diagnosed It as a ceased UV joint.
When the garage contacted the AA to get claim number for repair they are knocking back the claim as wear & tear ??? has anyone experienced the same problem - the vehicle has only done 40,000miles has been serviced 6 times in this period all by approved landrover garages with the last service being just 3000miles ago .
I find it hard to believe that a UV joint would fault due to wear and tear with such little mileage .
I'm now being quoted £400 for replacement - is this reasonable - how hard to do myself or have I any grounds for complaint to the AA
advice would be appreciated
Post #368220 Wed Jan 02 2013 2:59pm
Bodsy
Site Sponsor
the part is abouit £50 and you can do it yourself if you are half familar with a socket set.
Its common for them to stick, quite often some WD40 and then some spray grease will get it going again for a short while.
I wouldnt class this as a wear and tear item TBH, but then again i'm not a warranty company.
You'll have to read the small print. If it has siezed, then it could be classed as a failure, if it is just a wobbly joint, then perhaps worn and not failed....?
They'll always try to get out of paying if they can. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #368223 Wed Jan 02 2013 3:29pm
mjbrr
United Kingdom 2009 Range Rover Sport TDV8 HSE Santorini Black
My steering is a bit heavy when not on the accelerator.
Do you have a photo of location of uv joint?
Wondered if giving mine a squirt of silicone might help. 2009 3.6 TDV8 HSE Santorini Black
Post #368227 Wed Jan 02 2013 4:02pm
Bodsy
Site Sponsor
This might help you.
http://www.disco3.co.uk/forum/topic56798.h...teering+uj Bodsys Brake Bible
See it HERE
Post #368228 Wed Jan 02 2013 4:13pm
Hulmey14
Thanks bodsy been looking for a diagram - didn't think to look on the disco site
Looks like it will be getting jacked up on when on nights at work
thanks again
Steve
Post #368232 Wed Jan 02 2013 4:46pm
ShooterNeil
England 2007 Range Rover Sport TDV8 HSE Java Black
Order from a dealer before 14.30
Then if its not in stock it will be there next day for you
Cost about 64£ from what I was told
I had mine swapped 3 weeks ago
Post #368256 Wed Jan 02 2013 8:16pm
