![]() | Home > Wheels & Tyres > Cracked Alloy - what to do? |
wilburn Member Since: 09 Aug 2010 Location: Shropshire Posts: 82 ![]() ![]() ![]() |
duckworthparts Site Sponsor Member Since: 13 Mar 2009 Location: Market Rasen Posts: 674 ![]() ![]() |
got a picture of the alloy?
sparky8181 Member Since: 02 Nov 2012 Location: West Midlands Posts: 588 ![]() ![]() |
Email the company and find out what weight the wheels are rated for, there have been discussions on here re wheels cracking due to the weight of the RRS.
yep i've got this this style wheel in stock with a goodyear take off tyre on has maybe covered a thousand miles or so.
Hi Sounds, good. We are unable to collect as too far (we are in Whitchurch Shropshire). Tyres on car at moment are Accelera Iota 275/40/ R20 106Y XL I don't suppose you are able to supply with same tyre? Also, how much for delivery please? Thanks Paul |
Hi Paul
Hi, Ok, I'll take the wheel and tyre for £250 + vat plus free delivery. I'll email you now. Thanks Paul |
Bandit8 Member Since: 20 Oct 2012 Location: Essex Posts: 99 ![]() ![]() ![]() |
I would just like to say that that thread was well done. Well done to duck worthparts for sorting that out at a lot less price than the stealers.
And not a mention of boobies! |
Two quick questions, is the tyre on the wheel a directional tyre? As it is to replace front nearside wheel. At the moment I have the space saver wheel on which is a 255/50/R19 107Y Continental Cross Contact. What psi should I have it set to? Fronts are 'normally 33psi and back 36psi but not sure if the different size wheel/tyre should be at a different psi? Thanks Paul |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
The sticker on your drivers door tells you the pressures for the different sizes. I believe 33 is correct for 19s. |
Ah, so it does, I missed that it also list 19" next to 20" I just saw the reference to T175/80R19 122M at 60psi and thought - what the hell is that about. Thanks ![]() |
Agree it is great to see everyone working together and finding a solution for the IP. Only one thing a bit worrying - looks like he is going to end up with odd tyres on the same axle and worse still they won't be evenly worn. Doesn't this put a strain on the various expensive bits of transmission with their associated clutches and differentials and bits it seems no-one understands? Remember tyres are cheaper than new transmissions.Think I would be happier with two new tyres on that axle. Any technical experts like to cast some light here?
