![]() | Home > Faults & Fixes > whining when accelerate and idle |
Drive belts ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 114 ![]() ![]() ![]() |
wife or partner, mine always whins under acceleration |
As above belts or alternator |
joeand Member Since: 22 Aug 2012 Location: manchester Posts: 104 ![]() ![]() ![]() |
Wouldn't the battery drain if it was the alternator |
Not necessarily, it might be the bearing and not the electrics side of things |
its usually the Air Con Compressor bearing, you can replace the bearing and clutch set for aboiut �70 parts.
Garage as rang me they Think the noise is cuming from water pump but noise is louder on the charger ? |
MGO Member Since: 29 Jan 2011 Location: Leinster Posts: 156 ![]() ![]() ![]() |
Alternator.
2 garages looked both could hear it but couldn't pinpoint where it was coming from told me to wait till its packs up |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
TBH if it is from the water pump then I'd rather not leave it till it packs up |
I've try turning air con off noise still there if I change the water pump and the noise still there I've wasted money |
Don't superchargers whine on acceleration anyway |
It never whined like this before ? |
Perhaps its like a women, they get worse as they get older. |
