![]() | Home > General > RRS tdv8 engine won't run |
Jamma88 Member Since: 23 Dec 2012 Location: Middlesbrough Posts: 24 ![]() ![]() ![]() |
I use a place called falcon performance but can't get in there till 2nd of jan |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 ![]() ![]() ![]() |
Try northeastern they know sports inside out.
Tried bleeding the fuel valve this morning Christmas morning under the bonnet lol still not starting :/ merry Christmas ppl |
Join the RAC or AA as a christmas present to yourself |
Tht would just be greedy I bought the car as my crimbo present lol |
Remove the turbo hose at the engine inlet manifold end, see if the will engine start, if it does then check the remaining turbo pipes for de-lamination, the inner wall of a turbo pipe can come unbounded from the outer layer and block air to the engine. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Example of delamination from a Disco 2 TD5
Ill havea check of tht I'm abit of a novice when comes to mechanics do u know where in the engine the turbo hoses are located ?? |
FF1078 Member Since: 25 May 2011 Location: East Yorkshire Posts: 69 ![]() ![]() ![]() |
I've seen this on 2 TD5 intercooler hoses,the inner lining of the hose comes loose from the outer,then when you ask the engine to rev it sucks the inner lining of the hose together and therefore strangles the engine of air,this then causes tons of black smoke and the engine cant breath so packs in,as someone else stated, try disconnecting the inlet hoses from the engine and see if it runs regards Nick 10 TDV8 Santorini |
Right lads I've got it started took intercooler pipe off and she started intercooler blowing smoke and oil out when trying to accelerate and will only accelerate to 3000 rpm are my thoughts right and my turbo has gone? |
As you've only had it a week take it back to where you bought it or was it a private sale?
2015 Golf R DSG Gone 2013 Mercedes C220 CDi AMG Sport Plus Gone 2008 2.7 RRS HSE |
Private |
Remember, she will NOT rev as easy as with the turbo pipe disconnected you are running the engine minus the turbo. However the fact that she will now run is a good sign.
Is a nightmare sick now am goin on holiday in 4 days so a. Just gunna leave it with the farther and let him sort it and just pik it up when I get home along with the big bill lol |
