![]() | Home > Off Roading & Green Laning > Rock sliders |
disco4x4au Member Since: 17 Nov 2009 Location: Perth Posts: 147 ![]() ![]() ![]() |
I have a bit of underbody protection for the 2010+ RRS. Fitted to mine are sliders, front bash plate, compressor plate and transmission plate. I suppose freight to your side of the world would be an issue though |
taff Member Since: 09 Jul 2012 Location: Pembrokeshire Posts: 49 ![]() ![]() ![]() |
Still trying to find rock sliders, have been think about getting a set for disco 3 and seeing if they can be modified to fit, anyone tried it? Range Rover Vogue Classic 3.9 V8 1992
RLD Site Supporter Member Since: 17 Mar 2006 Location: up north to one side Posts: 147 ![]() ![]() |
there is every chance they may fit as it is the same chassis |
That did cross my mind, wheel base is 5.5 inches shorter I think? Range Rover Vogue Classic 3.9 V8 1992
it is a shame your not near me as i do have some in but no end's welded on and no tubes for them at the moment we could have tried them . If it can be made i will try if not i am up in a wood some where may be over the rain bow
Living down here does often cause that problem, been looking at the britpart ones for disco 3, see there are 5 holes for securing to chassis, will take off plastic trim on my sport and see if they are similar.
would not think they are any different at all the tubes may be to long but holes should be the same If it can be made i will try if not i am up in a wood some where may be over the rain bow
SweNic Member Since: 26 Aug 2017 Location: Stockholm Posts: 10 ![]() ![]() ![]() |
@taff
The RRS's doors wrap round the bottom edge of the cill, the D3's don't. The D3 is also longer so any item will need to be cut and adjusted. Likelihood is that D3 items won't fit the RRS. 2012 SDV6 - it's missing a couple of cylinders
For a minute there i was getting excited when i see this thread resurrection Wayne |
rangemogger Member Since: 09 Nov 2010 Location: Canary Islands , Spain Posts: 45 ![]() ![]() ![]() |
I have made my own custom set , it is really not so hard if you deal with the right metal worker . Now I have legalized the sliders , winch mount , compotives+oversized tyres , etc... |
Chris, it wasn't me that resurrected it...I got a bit excited when I saw the new post too! |
Any pics? Always liked the OffRoving sliders ![]() 2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18” Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning 😎 |
