Home > Off Roading & Green Laning > Rock sliders
Page 6 of 6 <123456
They do look nice and understated on the vehicle. Thumbs Up
Does the slider stick out past the door moulding? I assume it does but in the piccies it looks close. 2012 SDV6 - it's missing a couple of cylinders
Post #589637 Fri Nov 01 2019 12:04pm
Pufftmw
It does stick out, though as you said, tight in places. Pic is from where it's closest and despite image pole was vertical. Gap was 1/2 cm I would say
Post #589639 Fri Nov 01 2019 12:54pm
HughN
Wales
I can think of a tree-stump on Salisbury Plain that I need those for. It's got me twice!
Post #589644 Fri Nov 01 2019 2:16pm
Pufftmw
I'm thinking some of the narrow lanes around Brechfa, in particular so-called Panel Beater Shocked
Post #589645 Fri Nov 01 2019 2:29pm
Buckster
Do the original plastic trims stay in place along the sill? Would like to see some more pics please with doors open please Very Happy 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
2013 SDV6 HSE Black Edition- Orkney Grey with Ebony & Ivory. LR Facelift RAI, Genuine G4 Expedition Rack, 4x Warn SBD-160 Spotlights, Warn 9.5XPS Winch, Mantec Underbody Protection and Sump Guard, Full Easy Lift Suspension Module, LR Light Guards, Light Force HTX230 Hybrid spotlights, 18โ€ Compomotive PD1881 on 265/65/18 BF Goodrich KO2, ARB fridge, TuffTrek awning ๐Ÿ˜Ž
Post #589656 Fri Nov 01 2019 8:02pm
Pufftmw
Just finished doing the other side, took about an hour all in all but that's because a) I again had problems getting out the rear two Phillips on the plastic valence b) I'm somewhat space limited and c) on my own. To be fair I wasn't in a rush either. I'll do pics another time as its still peeing down here.
Its really just a bolt on experience. I can imagine with two people and a newer less abused/rusty/muddy car it could be done in around 30 mins a side.
Plastic trims... The plastic valence is removed and discarded. The finish makes it look tidy when opening the doors. If you don't have have knackered Philips screws in the rear wheel arch then you'll be able to save/re-use. You probably don't have to but I did, remove the yellow pop-lock halves that hold the valence on but I imagine they might get crushed when tightening up.
OTH the front (rear) outer plastic wheel arch protector (again 2 Phillips but they worked!) needs to have a little bit of a chunk cut out of it (about 4" x 4.5" Wink ) in order to clear the slider. Not a problem for me but I've suggested to AJS that they provide a pre-cut one in the kit.
Post #589658 Fri Nov 01 2019 8:37pm
Pufftmw
Sun came out for a few minutes this morning!
As you can see the finish line mirrors where the plastic valence would have been.
Countersunk washers with Allen bolts
You can see some of the rust on rear quarter - other side is worse Shocked
Post #589672 Sat Nov 02 2019 11:14am
andyslandy
England 2012 Range Rover Sport SDV6 SE Tonga Green
Wish mine had not come with the steps on as i really like the look of these, also Pufftmw if your winch mount is an LR product then it is the G4 winch cradle.
Post #589679 Sat Nov 02 2019 2:12pm
Looking at the various pictures, I'd say these are solely tree sliders intended to stop a tree or rock from hitting the door. They're not rock sliders (they'd have a smooth underside if they were) and they don't look like they would take too much vertical load without risk of deflecting and preventing the door opening. 2012 SDV6 - it's missing a couple of cylinders
Post #589686 Sat Nov 02 2019 3:51pm
Pufftmw
You're probably right. I have already given the feedback about dual rock/tree sliders, so they might make a change maybe. They are pretty sturdy though, so I imagine would take quite a bit of vertical punishment before coming out of place. This is the same design they use for other tree sliders, so I guess they know what they're doing.
Besides, they're also helpful to get up into the cabin for a short-arse like me Whistle
Post #589711 Sat Nov 02 2019 7:32pm
rangemogger
Spain 2008 Range Rover Sport TDV8 SE Rimini Red
Iยดm agree , this design is closer to a side step ( very sturdy ) than a tree/rock slider , the load will be transmitted to the sill not to the frame (aka chassis ) and will bend . You should use the underside bolts and the two body to chassis mounts per side Wink TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #589717 Sat Nov 02 2019 9:38pm
Buckster
rangemogger wrote:
Another instructive view
And this is why I would like this design, as it covers all bases. The AJS one looks more sidestep design but stronger, so wont be for me Neutral 2003 BMW M5 - 5 Litres of V8 Optimax Slurping Goodness in Carbon Black
Post #589738 Sun Nov 03 2019 8:36am
Guyzer73
Happened across this site when looking for sliders, and underbody protection:
https://voyagerracks.com/land-rover-range-rover-sport-accessories 2006 RRS S/C CONSTANTLY under modification...
Post #589748 Sun Nov 03 2019 10:49am
rangemogger
Come on!! I hope this video will give motivation in the fab process  TdV8 mapped and egr deleted , 265/60 r18 on Compomotive rims , Navarricos underbody protection , custom rocksliders , Devon44 hidden winch 9500i , IIDTool
Post #592546 Mon Dec 30 2019 7:52pm
boostedt0y
United States
Voyager sliders on my l320
Post #607666 Sat Dec 19 2020 8:46am
Page 6 of 6 <123456
