![]() | Home > Technical > passenger doorlock |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 ![]() ![]() ![]() |
I think you disable the auto locking function when you go above 5 mph from the display in the dash, I've had it up once by using the 'i' button on the LHS stalk, keeping it pressed in for a while iirc then using the >> & << buttons on the steering wheel to select or de-select. HTH. |
range17 Member Since: 08 Oct 2012 Location: bedford Posts: 109 ![]() ![]() ![]() |
i see how that would work thankyou ,but i thought that if you were at a stand still you would be able to undo any door without having to press the dash button ,you can on the rear doors and drivers door but not passenger door ![]() bmw gs1200 adventure defender 90 off roader |
You mean before moving or when stopped, after moving?
after coming to a stop and just on front passenger door ,is there child lock on this door ? zx12r bmw gs1200 adventure defender 90 off roader |
mav101 Member Since: 22 Jan 2013 Location: Bromyard Posts: 28 ![]() ![]() ![]() |
got exactly the same oddity... when stopped (after moving, engine still running) have to press the button to open the passenger door... doesn't really seem right... there isn't usually child locks on the front passenger door of cars? |
I have had to disable the auto-lock to solve mine ![]() bmw gs1200 adventure defender 90 off roader |
Gerico Member Since: 02 Jul 2011 Location: Essex Posts: 224 ![]() ![]() ![]() |
I find you just pull the handle twice and it opens fine. I think some call it a deadlock system. Fair enough you can disable it but you might find some unwanted company when sitting at traffic lights (or similar) one day |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 ![]() ![]() ![]() |
if you leave it in drive, then the doors remain locked, its a safety feature to stop you being attacked at traffic lights, put the car in park and the doors can be opened without pressing the dash button, thats how it works on mine 2007 plate. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater |
surely you should be able to undo the passenger door from the inside though what ever gear you are in zx12r bmw gs1200 adventure defender 90 off roader |
thanks for the replies; still sounds a bit strange... would have thought you should still be able to open from the inside... will give the gear thing a try to see if it makes a difference though... when i get the car back... as it broke down on Saturday |
On later cars you certainly have;
