Home > Technical > passenger doorlock
range17
passenger doorlock
Hi ,does anyone know why i have to press the door unlock button on the dash each time my front passenger wants to get out unless i turn the car of ,its really annoying Evil or Very Mad zx12r
bmw gs1200 adventure
defender 90 off roader
Post #366643 Fri Dec 14 2012 6:51pm
Boost
United Kingdom 2007 Range Rover Sport TDV6 SE Zermatt Silver
I think you disable the auto locking function when you go above 5 mph from the display in the dash, I've had it up once by using the 'i' button on the LHS stalk, keeping it pressed in for a while iirc then using the >> & << buttons on the steering wheel to select or de-select. HTH.
Post #366646 Fri Dec 14 2012 7:49pm
range17
i see how that would work thankyou ,but i thought that if you were at a stand still you would be able to undo any door without having to press the dash button ,you can on the rear doors and drivers door but not passenger door Confused zx12r
Post #366648 Fri Dec 14 2012 8:39pm
Boost
You mean before moving or when stopped, after moving?
Not child locks is it?
Post #366655 Fri Dec 14 2012 10:14pm
range17
after coming to a stop and just on front passenger door ,is there child lock on this door ? zx12r
Post #366729 Sat Dec 15 2012 7:30pm
mav101
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
got exactly the same oddity... when stopped (after moving, engine still running) have to press the button to open the passenger door... doesn't really seem right... there isn't usually child locks on the front passenger door of cars?
Post #372801 Sat Feb 09 2013 12:03am
range17
I have had to disable the auto-lock to solve mine Confused zx12r
Post #372895 Sun Feb 10 2013 10:30am
Gerico
I find you just pull the handle twice and it opens fine. I think some call it a deadlock system. Fair enough you can disable it but you might find some unwanted company when sitting at traffic lights (or similar) one day Sad Shocked
Personally I'd stick with the 'double pull' or button press on the dash for piece of mind. Thumbs Up
Richard
Post #372903 Sun Feb 10 2013 11:20am
shakeapaw
if you leave it in drive, then the doors remain locked, its a safety feature to stop you being attacked at traffic lights, put the car in park and the doors can be opened without pressing the dash button, thats how it works on mine 2007 plate. 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #372910 Sun Feb 10 2013 11:38am
range17
surely you should be able to undo the passenger door from the inside though what ever gear you are in zx12r
Post #372969 Sun Feb 10 2013 8:03pm
mav101
thanks for the replies; still sounds a bit strange... would have thought you should still be able to open from the inside... will give the gear thing a try to see if it makes a difference though... when i get the car back... as it broke down on Saturday Sad
Post #372972 Sun Feb 10 2013 8:17pm
mse
On later cars you certainly have;
Drive away locking...where as you drive the car locks
One door unlock, where only the drivers door is unlocked
Normal and dead lock...the later prevents internal opening
Not sure the interaction of those systems for your fault Mike
2014 Facelift Discovery
Post #372991 Sun Feb 10 2013 10:55pm
