Home > Technical > Parking sensors again. |
Need the codes reading really. Just one faulty would stop them all depending on the failure. Bodsys Brake Bible
Sat Dec 08 2012 4:37pm |
5c0tty Member Since: 14 Sep 2012 Location: London Posts: 33 |
Does anyone now where the parking sensor control mod is? If I tap the boot floor the sensors come on fine, as soon as close the boot they go mad again.
Sun Dec 09 2012 11:41am |
cobbler2u Member Since: 09 May 2010 Location: hertfordshire Posts: 69 |
Ive got the same problem.
Fri Dec 14 2012 10:39pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
Control module is on the left hand side of the car, as you stand behind it, in behind the rear 1/4 panel trim. Failry easy to access if needed |
Fri Dec 14 2012 11:27pm |
Mckelvr Member Since: 08 Dec 2012 Location: Ayrshire Posts: 47 |
None of mine work tried them all today and when i went to the garage i bought the car from i was told by service dept, yea they are probably disconected for a reason as they are a nightmare , i sait WTF. |
Sat Dec 15 2012 12:01am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Ive noticed mine have been a bit intermittent in the cold weather. Some day fine some days front ones not working. FF 4.4 V8 Soooo looking forward to this bad boy
Sat Dec 15 2012 9:31am |
P7tey Member Since: 03 Oct 2012 Location: Devon Posts: 144 |
Mine fronts have been intermittent for a while. Since yesterday I'm getting "front parking sensors inactive" displayed on the dash, still intermittent. Need to get outside and investigate but it's too cold |
Sat Dec 15 2012 9:38am |
I had the whole system out, rear bumper off, took the pic module out and checked all the cabling. Put it all back together and everything worked. Hasn't been a problem for over a week.
Sun Dec 23 2012 8:14am |
robmeister1969 Member Since: 24 May 2008 Location: Surrey Posts: 125 |
i have suspension fault and intermittent parking sensor not working - if i switch off and on engine, the parking sensors work again. From what I've read, a new battery may fix the problem. I'm reluctant to replace the battery as i don't have a problem starting (RRS SC 2005) |
Sun Dec 23 2012 9:24am |
Likewise, if I give the car a run then turn off and on the error goes... More charge in the battery?? |
Sun Dec 23 2012 10:45am |
