Home > Technical > Parking sensors again.
5c0tty
United Kingdom 2006 Range Rover Sport TDV6 HSE Zambezi Silver
Hi guys
My parking sensors started to play up with the log tone and the flashing light. Checked around by putting the car in reserve and listening for the click. All the fronts work fine and I get the clicking. On the rears I don't get any clicking from any of the sensors. I've checked the loom connector behind the rear lamp.. All ok, I have taken the bumper off to look and can't see any broken cables. Still getting the long tone Sad
I'm lost now and would love some help
Cheers guys
Scotty
Post #365860 Sat Dec 08 2012 1:38pm
Bodsy
Site Sponsor
Need the codes reading really. Just one faulty would stop them all depending on the failure. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #365875 Sat Dec 08 2012 4:37pm
5c0tty
Does anyone now where the parking sensor control mod is? If I tap the boot floor the sensors come on fine, as soon as close the boot they go mad again.
Loose wire maybe??
Post #365993 Sun Dec 09 2012 11:41am
cobbler2u
England 2005 Range Rover Sport TDV6 HSE Stornoway Grey
Ive got the same problem.
Will get it checked out on monday hopefully.
Any news on your
Post #366659 Fri Dec 14 2012 10:39pm
Disco_Mikey
Control module is on the left hand side of the car, as you stand behind it, in behind the rear 1/4 panel trim. Failry easy to access if needed Thumbs Up
Post #366661 Fri Dec 14 2012 11:27pm
Mckelvr
United Kingdom 2009 Range Rover Sport 4.4 V8 Stornoway Grey
None of mine work tried them all today and when i went to the garage i bought the car from i was told by service dept, yea they are probably disconected for a reason as they are a nightmare , i sait WTF.
Post #366662 Sat Dec 15 2012 12:01am
Bradders
Ive noticed mine have been a bit intermittent in the cold weather. Some day fine some days front ones not working. Big Cry FF 4.4 V8 Soooo looking forward to this bad boy
Ex 2006 RRS SC - garbage
Ex 2016 135i M Sport - dream car
Ex 2003 RS6 Avant - piece of cr*p
Ex 2014 320d X Drive, M Sport Touring - ok I guess
Ex 2007 RRS TDV8 - bloody loved it
EX 2007 FL2 XS - not so bad
Post #366682 Sat Dec 15 2012 9:31am
P7tey
United Kingdom 2005 Range Rover Sport TDV6 HSE Zermatt Silver
Mine fronts have been intermittent for a while. Since yesterday I'm getting "front parking sensors inactive" displayed on the dash, still intermittent. Need to get outside and investigate but it's too cold Laughing
Post #366683 Sat Dec 15 2012 9:38am
5c0tty
I had the whole system out, rear bumper off, took the pic module out and checked all the cabling. Put it all back together and everything worked. Hasn't been a problem for over a week.
But a soon as one problem goes, another one comes...I now have suspension fault, normal height only! : Big Cry
Post #367474 Sun Dec 23 2012 8:14am
robmeister1969
United Kingdom 2005 Range Rover Sport Supercharged Santorini Black
i have suspension fault and intermittent parking sensor not working - if i switch off and on engine, the parking sensors work again. From what I've read, a new battery may fix the problem. I'm reluctant to replace the battery as i don't have a problem starting (RRS SC 2005)
Post #367477 Sun Dec 23 2012 9:24am
5c0tty
Likewise, if I give the car a run then turn off and on the error goes... More charge in the battery??
Post #367483 Sun Dec 23 2012 10:45am
