Home > General > Tailgate will not open 2008 Sport
SRE
Spain
Closed the tailgate will a over full boot, the tailgate caught on the first catch now I have an semi open tailgate, it will not open on either the key fob or the button on the lower tailgate. The top half of the tailgate opens perfectly.
Is there an emergency opening method. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366591 Fri Dec 14 2012 10:40am
mse
Im not sure of a procedure...but have you tried to release whats stuck and assist the lock from inside the boot? Mike
2014 Facelift Discovery
Post #366595 Fri Dec 14 2012 11:06am
simple1
I know if the top part isn't closed properly the bottom will not operate. I recently changed the opening button as it did not always open and had gone grey, but to do this you have to have boot open to get panel off. Am not aware of an emergency opening procedure. I know after my experience, I removed my dog guard so I had access to boot via back seats. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #366598 Fri Dec 14 2012 11:18am
SRE
Spain
Also noticed that I have just lost the phone, so maybe the Bluetooth module and electric tail gate lock share a fuse. Just got to find the handbook now, I know I put it some place safe ? In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366618 Fri Dec 14 2012 1:45pm
GIXER JOHN
2006 Range Rover Sport TDV6 HSE Santorini Black
push tailgate hard at the bottom to close it .
it will then open
Post #366620 Fri Dec 14 2012 2:08pm
SRE
Spain
it will then open
Tried that initially, all it does is set the alarm off.
Mine is a 2008 with the electric closing tailgate latch. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366625 Fri Dec 14 2012 3:07pm
SRE
Spain
So off to the stealer, see what they say. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366626 Fri Dec 14 2012 3:08pm
Bodsy
Site Sponsor
have you tried getting someone to hold the lock and unlock buttons on the dash area for 20 seconds. whilst you are holding the tailgate to open it? Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #366631 Fri Dec 14 2012 4:53pm
SRE
Spain
Hi Bodsy
Tried holding both buttons down both with ign off and ign on.
Bluetooth phone connection is working again, I just re-paired the phone.
The top half of the tailgate was still working OK, however that has now stopped working as well.
Been to stealer who had a quick look at the fuses, all seemed OK, However I had checked them ALL anyway.
Driving home from stealer-ship, I heard a radio station from the tail gate / sub woofer area, only low volume though, I had this background radio station as well as my normal radio station playing together, also had this background station if CD was being played, so looks like something is supplying a back feed, maybe a relay.
Even though the tailgate is semi locked (seems like it's on the first catch) the dash display keeps saying tailgate open, also just noticed that the fuel flap does not lock when the doors are locked. All 4 doors lock OK although the horn gives a blast, also all the interior lights stay on. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366636 Fri Dec 14 2012 5:29pm
SRE
Spain
Yes boot area empty
Maybe an E mail into the Gaydon Electrical lads on Monday In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366639 Fri Dec 14 2012 5:42pm
SRE
Spain
Wrong info, the radio station I could hear in the back of the car was coming from a mobile phone that the mechanic had left in the boot area, it was some music he had on his phone that I could hear........so no back feed. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366642 Fri Dec 14 2012 6:02pm
SRE
Spain
Little update
Still not working, tried pushing in the middle of the lower tailgate when operating the boot release, I should also point out that there is no noise / sound from the electric latch whatsoever. Car is booked in the dealership on Monday, so could be a big bill in the offering, Big Cry however the car is still under Land Rover extended warranty. Whistle
Will post update as soon as we know the problem Thumbs Up In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #366692 Sat Dec 15 2012 11:09am
SRE
Spain
Tailgate working, no new parts needed, just a strip down of the trim from inside the car Thumbs Up
Warning.
I have been told not to lower the tailgate via the centre of the handle bit above the number plate, the part that houses the number plate lights and upper tailgate release switch. What is suspected is that I had a hand /finger on the upper tailgate release whilst lowering the tailgate, resulting in the top half opening whilst the lower half in in the process of locking.
Expensive lesson, Big Cry I will now just slam it from now on. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #367036 Tue Dec 18 2012 4:41pm
Bob.
Glad you got it sorted.
Three years ago I found it difficult enough to remove the tailgate trim with the tailgate open let alone closed. (I wanted to get at the tailglass lock to adjust it.)
I too initially used the obvious "handle" ie the opening switch on the tailglass - to close the tailgate until I found the two well hidden handholds built into the tailglass each side of the number plate lights. I have used these ever since and not had any more mislocks.
In case you haven't found them I have shown their location below. Sorry about the quality of the picture but it is an old one I happened to have.
Post #367148 Wed Dec 19 2012 9:08pm
mse
i just press the button and walk away Shocked Rolling with laughter
I genuinely miss the split boot, but the electric boot is cool Mike
Post #367237 Thu Dec 20 2012 4:26pm
