Home > General > Limp mode on my 2.7 sport need help |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
With all the differing failures it points to battery or alternator failure. Have had similar suspension issue in Germany of course, when car threw up suspension errors after sustained speeds of 100 plus but switching off and on reset system.
Sun Dec 09 2012 11:52am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4393 |
A blocked fuel filter can give similar symptoms, especially on 07MY and later cars |
Sun Dec 09 2012 7:29pm |
airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248 |
buy a hawkeye diagnostic tool best money you will ever spend
Sun Dec 09 2012 7:35pm |
Jamie-G Member Since: 18 Nov 2012 Location: oxfordshire Posts: 13 |
Thanks guys I will look at buying a diagnostic test, I am at home now waiting for the AA to collect the car and take it back to the garage. I have had it a week and none of the electrics are working correctly plus they let me drive it away with no tax in the window.
Mon Dec 10 2012 11:04am |
BigCat8810 Member Since: 20 Feb 2012 Location: Berkshire Posts: 132 |
My TDV8 is doing exactly the same thing, in terms of multiple fault warnings, limp mode and dropping to the bump stops. When I stop, shut down and re start it all returns to normal. I think it might be a battery as the heated seats and screen are slow to kick in but it is getting booked into local main agent as is under warranty.
Tue Dec 11 2012 10:16am |
Did they come back to you with a resolution Jamie? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Dec 11 2012 11:03pm |
Hello everyone, yes they came back with a few errors but mainly a blocked fuel pump and fuel filters. they have replaced all and investigated the electrics. so anyone with the same faults should go get it checked out especially if it struggles to start or takes longer than normal.
Fri Dec 14 2012 9:43am |
Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147 |
Egr valves all day long |
Fri Dec 14 2012 9:22pm |
