Home > Tips & Tricks > Lowering suspension with fob?
Harry HST
United Kingdom 2005 Range Rover Sport 4.4 V8 HSE Java Black
Hi
Is there any way of lowering the access height with your fob whilst the car is locked ?
Post #365276 Mon Dec 03 2012 3:54pm
I believe there is a feature that you can do it by having the hazard lights on and all doors shut, not sure if it's possible when the cars locked to be honest. Confused ON THE WAY: BMW F21 M140i
Post #365277 Mon Dec 03 2012 3:56pm
Montythegod
United Kingdom 2006 Range Rover Sport Supercharged Rimini Red
Ive programmed my fob to lower and raise.. but yes the hazards need to be on to do so, so its a bit pointless really...
Details to change the function of the third fob key are in the owners manual and was straightforward..
Oh and you need to press 2 buttons on the fob to lower or raise.. Whistle Why?.. Because i can....
RRS 2006 S/C Rimini Red Weekend toy
Subaru impreza 1998 2.0 340hp still here
Smart car 0.7 61 hp Carbon offset
Sierra cosworth 2.0 350 hp GONE
Various RS escorts, Vauxhall sri's Volvo T5's, BMW 3 series, fiestas (?) fiat's....
Mr Mischief - www.mischief-inc.co.uk Wink
Post #365297 Mon Dec 03 2012 6:19pm
.....and on MY12+ you don't need to program the function at the expense of something else Mr. Green Whistle ON THE WAY: BMW F21 M140i
Post #365298 Mon Dec 03 2012 6:22pm
Montythegod
Thumbs Up Why?.. Because i can....
Post #365300 Mon Dec 03 2012 6:24pm
mse
Nor on the 10 plus.
Shame the hazards button on the fob doesnt turn the hazards on. Mike
2014 Facelift Discovery
Post #365336 Tue Dec 04 2012 12:32am
big pimp
mse wrote:
Nor on the 10 plus.
I've followed the instructions in the manual, and still can't do it.
Is it a dealer feature? MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #365349 Tue Dec 04 2012 9:39am
mse
No standard feature - if its not working its your technique Shocked Mike
Post #365459 Tue Dec 04 2012 7:39pm
Montythegod
It took me several attempts to get it right Why?.. Because i can....
Post #365462 Tue Dec 04 2012 8:03pm
Mitchmx
I got a feeling so many people would have this feature. I would.
There must b away around it. Think we need bodsey to tackle this! Mr. Green
Post #365466 Tue Dec 04 2012 8:39pm
big pimp
You sound like my mrs!
I got it working - didn't realise I had to hold the 'lights' button on my MY10 keyfob to make it work.
Pretty cool! MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #365487 Tue Dec 04 2012 11:43pm
mse
Thumbs Up Mike
Post #365489 Wed Dec 05 2012 12:08am
JonnyDangerous
what sequence is needed to do this?
Post #365550 Wed Dec 05 2012 4:50pm
Here you go Thumbs Up
Quote:
REMOTE OPERATION
The Smart Key can be operated from inside or outside the vehicle. It is therefore important that it is kept out of the reach of children at all times. When operating the Smart Key from inside the vehicle, make sure that an adult checks for obstructions under the vehicle and supervises the raising or lowering process.
Care should be taken with all height changes, when a trailer is attached to the vehicle.
The buttons on the Smart Key may be used to operate the air suspension system, allowing the vehicle to be raised or lowered remotely.
This may be useful in attaching a trailer or loading the vehicle.
To change the suspension height using the Smart Key, the vehicle must be stationary, all the doors closed and the hazard warning lamps switched on.
To raise the vehicle press and hold button (1) (Open padlock), then press and hold button (2) (Boot release).
To lower the vehicle press and hold button (1) (Lights), then press and hold button (3) If the starting height is above or below normal height, movement will cease when normal
height is reached. Release the Smart Key buttons and press again to continue.
Post #365552 Wed Dec 05 2012 4:58pm
Mitchmx
Will that work on a my2006?
Post #365668 Thu Dec 06 2012 10:13pm
