Home > Tips & Tricks > Lowering suspension with fob?
Bodsy
Site Sponsor
No, only way with yours Mitch is with the hazards on Sad Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #365675 Thu Dec 06 2012 10:31pm
Mitchmx
Gurrr Evil or Very Mad
Post #365679 Thu Dec 06 2012 10:50pm
Aitchy
Beancounter_74 wrote:
Here you go Thumbs Up
Quote:
REMOTE OPERATION
The Smart Key can be operated from inside or outside the vehicle. It is therefore important that it is kept out of the reach of children at all times. When operating the Smart Key from inside the vehicle, make sure that an adult checks for obstructions under the vehicle and supervises the raising or lowering process.
Care should be taken with all height changes, when a trailer is attached to the vehicle.
The buttons on the Smart Key may be used to operate the air suspension system, allowing the vehicle to be raised or lowered remotely.
This may be useful in attaching a trailer or loading the vehicle.
To change the suspension height using the Smart Key, the vehicle must be stationary, all the doors closed and the hazard warning lamps switched on.
To raise the vehicle press and hold button (1) (Open padlock), then press and hold button (2) (Boot release).
To lower the vehicle press and hold button (1) (Lights), then press and hold button (3) If the starting height is above or below normal height, movement will cease when normal
height is reached. Release the Smart Key buttons and press again to continue.
what is button 3? My 2010MY RRS 3.0 TDV6SE is Nara Bronze with Almond leather, straight grain walnut trim, 20" 15 spoke alloy's, mood lighting and power fold mirrors Gone
Post #365766 Fri Dec 07 2012 3:40pm
big pimp
Quote:
REMOTE OPERATION
what is button 3?
On our MY10's I've found out its the headlight button on the keyfob MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #365820 Sat Dec 08 2012 12:50am
naubin
2013 Range Rover Sport SDV6 HSE Santorini Black
So I have been trying this with my MY13 and I cant get it to work at all. I also have searched and cant find it in the manual either? Any ideas?
thanks
Post #384728 Wed Jun 05 2013 2:09pm
Welcome Smile
Page 83 of your handbook Whistle
 ON THE WAY: BMW F21 M140i
Post #384729 Wed Jun 05 2013 2:20pm
naubin
Thank you... I was searching on the PDF and it didnt find remote operation...
Shame about the hazzards - I wanted it making it easier to get the baby in at times...
Post #384730 Wed Jun 05 2013 2:32pm
Just get into the habit of sticking it in access mode before you stop. Wink
I do this as second nature now, means the car is always in access height when I go to get back in Smile ON THE WAY: BMW F21 M140i
Post #384731 Wed Jun 05 2013 2:39pm
urimg
Italy 2007 Range Rover Sport TDV6 HSE Sumatra Black
Isn't any problem to low and rise a suspension any Time that you want to drive.
Post #404533 Sun Dec 01 2013 11:08pm
