Home > Technical > Turbo replacement |
Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60 |
Took car to an independent LR dealer today for a second opinion on the P132B fault after 1/2 hour of them thrashing it about with the auto logic machine plugged in they came up with the dreaded news - the turbo is stuffed
Fri Nov 30 2012 11:07pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4402 |
Comes out from underneath. Exhaust needs to be removed |
Sat Dec 01 2012 9:04am |
Pictures of the turbo removal, this is the first time I've done this so did it at my pace and maybe took more off than I need to.........
Sat Dec 01 2012 7:43pm |
Bob. Member Since: 02 Feb 2009 Location: SWest Posts: 275 |
+1
Sat Dec 01 2012 8:53pm |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
V. good write up with pictures Boost. My vehicle has just developed P0046 fault code which is 'Turbo/Super Charge Boost Control Solenoid A Circuit' according to my Hawkeye.
Sun Dec 02 2012 10:43am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
A brave man indeed - great write up too. Hope all goes back ok FF 4.4 V8 Soooo looking forward to this bad boy
Sun Dec 02 2012 12:01pm |
Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657 |
I wouldn't dare attempt what you've done 2015 Golf R DSG
Sun Dec 02 2012 12:47pm |
That's a different code to what I got, mine was P132B, but the description sounds exactly the same, I had mine checked by 2 different dealers before I took the plunge - I'm sure someone on here may be able to tell you or offer some adive. |
Mon Dec 03 2012 8:04pm |
A lot of turbo suppliers insist on changing the oil supply pipe - why? No mention of this in the LR procedure for changiing?
Mon Dec 03 2012 8:18pm |
Cam sensor, or a fuel rail pressure sensor |
Tue Dec 04 2012 6:54am |
Thanks Mikey, I was planning on trying that tonight..........
Tue Dec 04 2012 9:37pm |
Nope, there is no gasket between the manifold and turbo. Great design May be worth mentioning that there might be an Engine Management software update, which sweeps the actuator through its full length of movement every time you start the car, to help prevent any future seizures |
Tue Dec 04 2012 10:15pm |
Hi Boost, where did you get the turbo charge from and how much? I'm thinking of doing mine. Keep us up to date. Thanks 2005 RRS TDV6 HSE Java Black 2005 997 C2 |
Wed Dec 05 2012 3:45pm |
I googled for them and fired about 6 E-mails off to different companies. various responses from repairing mine (seals & bearings - £195), reconditioned one (£395) then various prices for a full new unit, up to £1400+vat!!!
Wed Dec 05 2012 9:00pm |
