![]() | Home > General > range rover sport reverse camera install |
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Hi, did mine diy for about £260. straightforward job if you fancy having a go.
karan538 Member Since: 30 Oct 2012 Location: uk Posts: 89 ![]() ![]() |
hi just went on the website. they only sell lights parts cannot find any upgrades for a reverse camera?
listed under accessories at the top of the page, several different camera options. i went for a camera that mounts close to the tow bar cover as the install is easier, it has night vision and cost about £30. gvif unit is about £230 MY16 AUTOBIOGRAPHY Indus silver with some toys
Found it thanks alot. How well does the unit work and hows the picture quality? |
there is a dvd unit under the seat for the sat nav. the unit plugs into that and stays under the seat then is displayed on the sat nav screen. all works well and looks factory fit as there is nothing to see.
it is all very seamless, when you engage reverse the camera comes on and displays on the screen and disappears when you disengage reverse. picture quality is great and i can reverse into a dark garage at night to within an inch or so with no problem. wouldnt be without it now
can you send me a link to the camera you bought. You just saved me around 250pounds lol becuase I was going to buy the nav tv one tommorow |
no link but the hids4u product number is LSTC109NL it is described as a 22.5mm bullet type camera at £20.43 and the main unit is product number GVIFDISCO3V6.2 at £239.99
check out the post a few moments ago for a gvif unit ...... MY16 AUTOBIOGRAPHY Indus silver with some toys
Found it thanks, will be ordering that tommorow. |
lee551247 Member Since: 23 Aug 2012 Location: Cheltenham Posts: 287 ![]() ![]() |
Hi Rigsby, Did your Range Rover come with the factory fitted freeview tv? I have the factory screens in the headrests too, do i have to purchase the multimedia interface or is there a way of connecting the camera to the factory screen without the interface? Also with your camera mounted low down does it not keep getting covered in grime and spray from the roads? Thanks Lee |
Hi Lee, mine has the free view but no rear screens. As far as I know you will still need the GVIF unit unless you already have one for the rear screens if aftermarket. Not had any issues with dirt or water with the camera mounted by the tow bar cover and gives a really good picture too. Regards Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
