Home > General > range rover sport reverse camera install
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
Hi guys, I want to get a reverse camera installed in my range. I have called a couple dealers and heres the minimum quote i got:
100 camera cost
500 for unit which allows camera to go into factory screen
150 labour..
I want the camera to work in the original screen
but apparently only nav tv makes them for my range and that unit is 500pounds.
Has anybody ever got a reverse camera installed. Is there any unit less then 500 pounds which allows the reverse camera to connect?
I have a 2008 range rover sport hse with tv tuner + sat nav
Help would be greatly appreciated. thanks
Post #364921 Thu Nov 29 2012 6:24pm
rigsby
Hi, did mine diy for about £260. straightforward job if you fancy having a go.
Unit and camera from hids4u .
rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
2012 3.0 SDV6 Luxury gone, but a great motor
Post #364922 Thu Nov 29 2012 6:27pm
karan538
hi just went on the website. they only sell lights parts cannot find any upgrades for a reverse camera?
+ Found it thanks. How well does it work with the car. Also does your car have the range rover tv tuner?
and did you install it straight into the navigation head unit? thanks
Post #364923 Thu Nov 29 2012 6:31pm
rigsby
listed under accessories at the top of the page, several different camera options. i went for a camera that mounts close to the tow bar cover as the install is easier, it has night vision and cost about £30. gvif unit is about £230 MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #364924 Thu Nov 29 2012 6:35pm
karan538
Found it thanks alot. How well does the unit work and hows the picture quality?
Post #364925 Thu Nov 29 2012 6:36pm
rigsby
there is a dvd unit under the seat for the sat nav. the unit plugs into that and stays under the seat then is displayed on the sat nav screen. all works well and looks factory fit as there is nothing to see.
mine came with tv and freeview but dont know if it was aftermarket or factory fit but shouldnt matter either way
Post #364926 Thu Nov 29 2012 6:39pm
rigsby
it is all very seamless, when you engage reverse the camera comes on and displays on the screen and disappears when you disengage reverse. picture quality is great and i can reverse into a dark garage at night to within an inch or so with no problem. wouldnt be without it now
Post #364927 Thu Nov 29 2012 6:43pm
karan538
can you send me a link to the camera you bought. You just saved me around 250pounds lol becuase I was going to buy the nav tv one tommorow
Post #364928 Thu Nov 29 2012 6:48pm
rigsby
no link but the hids4u product number is LSTC109NL it is described as a 22.5mm bullet type camera at £20.43 and the main unit is product number GVIFDISCO3V6.2 at £239.99
speak to Hannah
Glad to help regards rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #364930 Thu Nov 29 2012 7:03pm
rigsby
check out the post a few moments ago for a gvif unit ...... MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #364934 Thu Nov 29 2012 7:08pm
karan538
Found it thanks, will be ordering that tommorow.
Post #364935 Thu Nov 29 2012 7:15pm
lee551247
rigsby
Hi Rigsby, Did your Range Rover come with the factory fitted freeview tv? I have the factory screens in the headrests too, do i have to purchase the multimedia interface or is there a way of connecting the camera to the factory screen without the interface?
Also with your camera mounted low down does it not keep getting covered in grime and spray from the roads?
Thanks
Lee
Post #365749 Fri Dec 07 2012 12:13pm
rigsby
Hi Lee, mine has the free view but no rear screens. As far as I know you will still need the GVIF unit unless you already have one for the rear screens if aftermarket. Not had any issues with dirt or water with the camera mounted by the tow bar cover and gives a really good picture too. Regards Rigsby MY16 AUTOBIOGRAPHY Indus silver with some toys
Post #365768 Fri Dec 07 2012 2:52pm
