Home > General > Drivers swimming pool |
broncoupe Member Since: 24 Jul 2011 Location: dorset Posts: 61 |
Cheers Andy door seal is new also the outer seal to the glass is new |
Sun Nov 25 2012 10:00pm |
npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716 |
Has any work been done on the door at all? Wondering if the plastic sheets that seals the inside might be letter water in behind the door card
Sun Nov 25 2012 10:06pm |
bigphil99 Member Since: 14 Dec 2011 Location: N. Ireland Posts: 17 |
I had this issue with mine although definatly not as much water. I fixed it with this http://www.rrsport.co.uk/forum/topic20562....trim+water
Sun Nov 25 2012 10:16pm |
I would put my other half in the car and put an hosepipe in various places around the bulkhead if no leak is found then work it up the side of the windscreen untill your other half sees it pouring in If it doesn't come in once you have covered the screen try either the sunroof and the door seals, just because you have had new ones its not impossible for them not to leak. The only other time ive head of such a wet carpet was on a FFRR when the A/C or heater matrix corroded and sprung a leak behind the dash causing the carpet to get wet. Good luck. |
Sun Nov 25 2012 10:19pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
From the questions i asked in earlier postings i was trring to figure out if the door membrane had been messed about with and not put back together correctly. If you've had a new window regulator, lock or wing mirror then it's likely that the membrane wasn't put back together properly.
Sun Nov 25 2012 11:46pm |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 |
I had exactly the same problem last year, soaking wet drivers floor mat, searched all over and couldn't find the source of the water. I dried it all out and touch wood it has never happened again! |
Mon Nov 26 2012 9:52am |
The power of hope pleased yours is ok I find my self a bit more sceptical.
Mon Nov 26 2012 6:04pm |
Hello mate,
Tue Dec 18 2012 1:13am |
