Home > Off Topic > Towing pole Vs Rope |
Bandit8 Member Since: 20 Oct 2012 Location: Essex Posts: 99 |
Very. Obvious. Stupid. Answer..... [/b] It is what it is and I am what I am.... |
Mon Nov 19 2012 8:24pm |
A word of cautioin
Wed Nov 21 2012 6:33pm |
kp Member Since: 18 Jan 2012 Location: Ex Bashing! Posts: 91 |
I've used the stropp once in an emergency as a mother and child were in a very bad spot of the m18 as it was perfect for the job.
Wed Nov 21 2012 8:26pm |
The centre point tow ring (front and rear) is perfectly fine (i referenced that in my post) using a stop on a tow ball is dangerous A strop on a tow ball, especially when just slotted on it, will at the very least walk off with ease and use - seen that Whilst a braced drop plate may give the impression of being "incredibly strong" and you might think with a tow rating of 5t it is, its actually not - ive seen one bend and bent post recovery off road - they are not designed for it - very different forces etc. It might get you by on a short road rescue - but i would use extreme caution Mike 2014 Facelift Discovery |
Wed Nov 21 2012 10:19pm |
I've seen what the l322 ones are capable of and they wouldn't break before the strap
Wed Nov 21 2012 10:28pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
Many thanks for the responses chaps, really appreciate it
Wed Nov 21 2012 10:57pm |
I think we will have agree to disagree - nothing should use the towball strop eye or shackle - you should extract from a fixed point,locked with a straight angle and distributed point. The sport and disco have this point BUILT IN so no need to use the pifflingly small towball which is not designed for extraction. Ill try and get a photo for you to see how rubbish a towball is for extraction etc Mike 2014 Facelift Discovery |
Thu Nov 22 2012 7:16pm |
