Home > Off Topic > Towing pole Vs Rope
Page 3 of 3 <123
Bandit8
England 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
Very. Obvious. Stupid. Answer..... Thumbs Up [/b] It is what it is and I am what I am....
Post #363726 Mon Nov 19 2012 8:24pm
kp
The sprung type is the better one for the few pennies more.
having towed and been a tower a few times and recovered a few times as well i can say its the better one to go for as a softer strain on each vehicles tow point.
Also while at Machine mart get the 5tonne recovery strap and the correct D links for it rated to 6+ tonnes so the snatch gives up before them. They fit just nice over a tow ball and are strong enough to pull a stuck D3/4/SSRR/FFRR from being bellied in mud without snapping and have a little give in them as well. Plus if they do snap they flail a lot so the energy dissipates very quick, kinda like plasma rope though maybe not as good but still dam good.
Also IIRC on the SSRR you can take the towing electrics cover off and there is a loop there that can be used for the recovery straps if needs must(ie your tow ball is deep in there or isnt fitted before going into a situation...) FFRR Owner, SSRR engine destroyer!(*2) & Creator of SSRR Smile
Post #363961 Wed Nov 21 2012 3:58pm
mse
A word of cautioin
You should never tow someone with a strop (or even a shackle tightly over a tow ball) on the tow ball Exclamation Exclamation .
Its not designed for it - ive seen them pop off, break, bend and do some serious damage. Caravan and trailer hitches are totally different in forces etc that towing like this on a towball.
Off road its even worse Exclamation
Use a fixed RATED anchor point - your spoilt on the sport and disco, there is one on the front and rear and even better nicely in the centre for a direct pull. Mike
2014 Facelift Discovery
Post #363980 Wed Nov 21 2012 6:33pm
kp
I've used the stropp once in an emergency as a mother and child were in a very bad spot of the m18 as it was perfect for the job.
The disco and rrs centre rear point is there to help prevent chassis twist Wink
A properly fitted tow ball is incredibly strong! Not like the sorry excuse LR class as fixed or removable on the disco or sports. The l322 one is much much better strangely! FFRR Owner, SSRR engine destroyer!(*2) & Creator of SSRR Smile
Post #363989 Wed Nov 21 2012 8:26pm
mse
The centre point tow ring (front and rear) is perfectly fine (i referenced that in my post) Thumbs Up using a stop on a tow ball is dangerous Exclamation Shocked
A strop on a tow ball, especially when just slotted on it, will at the very least walk off with ease and use - seen that
Whilst a braced drop plate may give the impression of being "incredibly strong" and you might think with a tow rating of 5t it is, its actually not - ive seen one bend and bent post recovery off road - they are not designed for it - very different forces etc. It might get you by on a short road rescue - but i would use extreme caution Mike
Post #364003 Wed Nov 21 2012 10:19pm
kp
I've seen what the l322 ones are capable of and they wouldn't break before the strap Wink
The shackle ALWAYS needs I out rate the strop and the shackle should never ever be slotted on to the tow ball as that is stupid and asking for big trouble. When mine is on it will not come off as its a snug fit.
I guess the l322 has the advantage with the fixed tow bar that it dissipates any shock load through the whole of the rear and not just a single point on the chassis as Long as the towball and its mount can hold which I know mine can Wink FFRR Owner, SSRR engine destroyer!(*2) & Creator of SSRR Smile
Post #364005 Wed Nov 21 2012 10:28pm
kav1187
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Many thanks for the responses chaps, really appreciate it Thumbs Up
I shall purchase the sprung bar and the strops are a good idea in case the other car doesn't have a proper towing eye (as per the gf's Matiz). I have and will only use the anchor point as it's pretty damn solid Cool
Thanks again guys Thumbs Up
Post #364009 Wed Nov 21 2012 10:57pm
mse
I think we will have agree to disagree - nothing should use the towball strop eye or shackle - you should extract from a fixed point,locked with a straight angle and distributed point.
The sport and disco have this point BUILT IN so no need to use the pifflingly small towball which is not designed for extraction. Ill try and get a photo for you to see how rubbish a towball is for extraction etc Mike
Post #364098 Thu Nov 22 2012 7:16pm
Page 3 of 3 <123
